No I alreayd have DRL, but I took out the bulbs. Should I put the bulbs back in?
Running angel eyes is a hell of a lot more sexy than running daytime running lights. It sounds like you have the ones similar to stock bimmers with a light bulb that reflects light through to the rings? Too bad it's not brighter, but I'd take those angel eyes constantly on over daytime running lights any day of the week.
You might be able to do an LED bulb setup in there. I've never taken those apart, so I don't know if there's room. If you did, it would brighten your angel eyes summat.
OOPS.
<--smacks self on forehead
When you said "DRLs" I failed to make the connection to "Daytime Running Lights." I thought you meant you had angel eyes, but had deactivated them by removing the bulb that illuminates them.
Doesn't your high beam bulb serve as the daytime running lights bulb? Isn't your high beam rather important to you?
No no, the DRL's are a small 5 watt bulb that is in the same location as the high beam bulbs, but not the same bulb, so basically I have high beams aswell as DRL's in my inner lamps.
Technically, thats wrong. DRL's run off the high beam bulb at a low output. The small 5 watt wedge bulb in the ZKWs are the city lights that they use in Europe as their parking lights. To have DRL's on an e36, you would need the module which is about 70.
__________________ - 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
