Clutch problems? - BMW Forum - BimmerWerkz.com
Old 09-08-2005, 12:45 AM   #1 (permalink)
MalibuSean is an unknown quantity at this point
Clutch problems?
The clutch on my '97 m3 with 80k miles engauges just off the floor. I thought it's supposed to release shortly after it's pressed, towards the top. Is this correct? There doesn't appear to be any leakage from the master or slave cylinder and the clutch isn't slipping so I don't think it's worn down that much. Is there a relatively common problem with the system or suggestions on what to replace? Thanks.
-Sean
MalibuSean is offline   Reply With Quote
Problems With Spec Clutch And Their Service... Dustin540-6 5-Series (E12,E28, E34, E39, E60) 4 08-09-2007 12:20 AM
E28 Clutch Problems (help!) limbick 5-Series (E12,E28, E34, E39, E60) 2 04-20-2005 03:25 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
