Clutch Help - BMW Forum - BimmerWerkz.com
Old 01-20-2005, 05:32 PM   #1 (permalink)
scashrine is an unknown quantity at this point
Need to replace the clutch on my 97m3 with 86000 miles. Ive heard UUC and AA tuning a lot. Which clutch is best for spirited driving?
scashrine is offline   Reply With Quote
Old 01-20-2005, 07:28 PM   #2 (permalink)
bmwforumerm3 is an unknown quantity at this point
dunno about sprint...
but I here if your getting a clutch and wanna "race"
you need to go with the double plated m5 clutch...its sick i here...can handle up to 600 hp.
-M Till The End
<span style='color:blue'>
My 1997 cosmos black m3
<a href='http://www.cardomain.com/memberpage/789780' target='_blank'>http://www.cardomain.com/memberpage/789780</a>
</span>
bmwforumerm3 is offline   Reply With Quote
Old 01-20-2005, 07:33 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
No so sure about the M5 clutch.. yes.. it works wonders in a car that is putting a lot of HP down.. but he has a 97 M3.. it would take a lot of work to push 500hp... which would be the only way that said clutch would be of good use...
AA Tuning makes great clutches... I would check around though... read some reviews... SACHS makes a good heavy duty clutch kit for our car... www.turnermotorsports.com sells them... good stuff there... they sell a few others... search around.. and call a few of the tuners.. they dont mind pointing you in the right direction...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 01-22-2005, 02:34 AM   #4 (permalink)
My bad I wasnt didnt see E36....ya 240 hp...may not be enough...but an E46 with all ur regular bolt ons...that should be a good one...lol
Ya AA is alright..
I like there exhuast a lot more than there short throws, turbos...all the other stuff
-M Till the end
</span>
Old 01-22-2005, 02:57 AM   #5 (permalink)
DoTheDew is an unknown quantity at this point
Highly recommend the M5 Clutch for Turbo or Supercharged E36's
But if yours isnt id say stick with OEM it is more then enough.
DoTheDew is offline   Reply With Quote
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Clutch Kevin325i 3-Series (E36) 13 08-06-2004 12:09 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
