Same with my 95 M3, got it for 2 weeks now, I thought the iddle was a lil bit rough when i bought my car. Replaced spark plugs, clean air filter. Still run the same, then I just bought the Fault scanner, and says i have Knock sensor 4-6? Im not sure if its a bad sensor? or it means something bad going inside my engine.
Engine runs perfect when stepping on gas, its just when its idling. Engine light is not On, I guess its not a priority error?
Needs your guys input, me and driva looks like have the same problem.
Thank you guys,
Will appreciate for any inputs or suggestions
