Camber and Toe Issue after lowering E39 M5 - Page 2 - BMW Forum - BimmerWerkz.com
Old 03-12-2012, 09:23 PM   #16 (permalink)
Car: 2000 BMW M5
E39m5 is on a distinguished road
I went to the shop, and mechanic that reviewed the problem (not the same that did installation) told me that alignment must be re-done.
He inspected my car for body/frame damage and there were none. So re-doing an alignment is the 1st steep. Unfortunately I was short time, plus I'll need to change front upper and lower control arms. So I figure I'll get my parts and re-do alignment then.
Planning to do it by the end of the month.
Will post an update after.
E39m5 is offline   Reply With Quote
Old 03-21-2012, 09:34 PM   #17 (permalink)
Car: 1989 BMW 535i
rivroshaun951 is on a distinguished road
I did it. I finally found the specs for your car. Yeah Yeah I know I'm 2 years late. But hear you go anyway.
WHEEL ALIGNMENT SPECIFICATIONS
Note: Given specifications are for car loaded down to normal position. Refer to Inspection Conditions See: Inspection Conditions
Front Axle
Total toe 0°10' ±10'
Camber (Difference between left/right max. 30') -30' ±30'
Track difference with 20°inside wheel lock -1°43' ±30'
Caster (Difference between left/right max. 30')
With ±10°wheel lock 6°27' ±30'
With ±20°wheel lock 6°49' ±30'
Front wheel displacement 0°±10'
Max. Wheel Lock
Inside Wheel approx. 41.5°
Outside Wheel approx. 32°
Rear Axle
Total toe
Alignment check 0°10' ±10'
Adjustment 0°10' ±8'
Camber (Difference between left/right max. 15')
Alignment check -1°50' ±15'
Adjustment -1°49' ±5'
Geometric axis deviation 0°±12'
Sorry it took me so long..
rivroshaun951 is offline   Reply With Quote
Old 03-21-2012, 09:56 PM   #18 (permalink)
Car: 2000 BMW M5
Thanks you for the info.
And here is an update; Last Sat I changed my upper and lower front control arms and tomorrow I am taking my car back to the shop to re-do alignment. I'll should know what's up with in the next 24 hours. Will post another update tomorrow.
Old 03-23-2012, 09:53 AM   #19 (permalink)
Car: 2000 BMW M5
Got my alignment re-done yesterday. Car aligned perfect. Rear tires also look even.
One thing that kind of surprised me; I thought that my front would be way off since I put new Upper and Lower control arms last weekend, but it was barely off.
I do have to admit, relapsing front arms was kind of pain. I probably spend about 4 hours in total labor. Out of those 4 hours; 3 hours to remove / 1 hour to put new parts in.
I really struggled getting old arms out. My hands look like I've been in to a bar fight........................But the satisfaction of doing work by myself is definitely worth the effort.
So I guess its all good.
Old 03-23-2012, 06:16 PM   #20 (permalink)
Car: 1989 BMW 535i
Congratulations man. Now step back and look at those hands. You sir are a true enthusiast.
Old 03-25-2012, 08:41 AM   #21 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Impressive, we like the "Hand-On" approach... Well done fella !
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 03-25-2012, 09:50 AM   #22 (permalink)
Car: 2000 BMW M5
Thank you guys.
Old 03-25-2012, 10:14 AM   #23 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Just glad I suggested the Re-Fit and everything is sorted
Eso es todo!
BMW Part Market
New Member ?
Old 01-25-2013, 06:52 AM   #24 (permalink)
alaam5 is on a distinguished road
Re: Camber and Toe Issue after lowering E39 M5
Hi i bought my new bmw m5 2002 and am searching for dinan suspension stage 1 do u have any or can u help me plz
Sent from my GT-I9300 using AutoGuide.Com Free App
alaam5 is online now   Reply With Quote
Old 01-25-2013, 10:43 AM   #25 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Dont know where you live so fill out your profile a little more.
I would recommend the Ground Control coilover kit instead. It will be about the same price, but better customer support should something happen. Ground Control is a top notch suspension system. Other brands you could look into are KW Coilovers.
Click HERE to see my E36 Blog
Old 01-25-2013, 11:34 AM   #26 (permalink)
Car: 2000 BMW M5
I use ST-Tech (made by KW) on my E39 M5. Got a complete kit for around $800 including shipping. Had them for about a year now and I just love it. Height adjustment is very easy and can be done at home. Just remember to re-aligned the car after each adjustment.
Old 02-13-2013, 03:35 AM   #27 (permalink)
Hi plz am new into this forum i would liken u to paste the link u bought ur kw adjustale suspensions from thanks alot for ur time
Old 02-13-2013, 10:20 AM   #28 (permalink)
Car: 2000 BMW M5
Just to clarify, I purchased ST-Tech which are made by KW in Germany. The only main difference between ST-Tech and KW is the warranty. I believe KW has lifetime warranty and ST-Tech only 5 years. Otherwise its the same product.
I purchased mine via eBay. There are bunch of seller selling the same product. I ended up getting mine from DV8. I ended up calling them and negotiated a price of $800 including shipping. Here is the link.
St coilover BMW M5 Sedan E39 00 03 | eBay
Old 02-13-2013, 10:56 AM   #29 (permalink)
I am very grateful for ur help but one last question did u feel a noticable change in control when u installed the suspension kit?besides does the car loses its comfort when u exhange stock suspensions with these ones?
Old 02-13-2013, 01:11 PM   #30 (permalink)
Car: 2000 BMW M5
I think the ride comfort remained the same. I had 5 people in the car and I was going about 85 MPH and the ride was perfect.
However I did not drop my car too low. I think I lowered front about 2 inches and rear about 1+ inches. (I am running 19x8.5 - 255x35 & 19x10 - 285x30).
Here are couple pictures.
I actually had to bring the rear back up about 1/2 of inch, because I was getting bad camber wear and there was no more room to adjust it.
The ride comfort will depend on how low you are going to drop your car. The lower the car, the less comfort you'll have. Plus I've noticed that if the car too low, tires wear out pretty fast. This is one of those things that you have to play around with before you get it the way you like it. Just keep in mind, every time you adjust the height, you need to re-align the car.
Camber and Toe Issue after lowering E39 M5-532347_10151440686285533_832646430_n.jpg   Camber and Toe Issue after lowering E39 M5-532347_10151440686280533_1784124711_n.jpg
M3 Camber issue! PLZ HELP!!!!! crs8089 M-Series (M1, M3, M5, M6) 3 08-14-2011 08:48 AM
Roof issue red light flashing! (and Sat Nav issue too!) doopranal Z3 / Z4 /ZM 0 03-24-2009 06:25 AM
Camber On E36 Shudogg 3-Series (E36) 0 12-13-2004 09:47 AM
Lowering Spring Height/camber Issue Questions... daxsandman 3-Series (E21, E30) 3 11-23-2004 10:14 PM
camber kit VeLoCiTy318 3-Series (E36) 4 08-18-2004 01:03 AM
