BMW M3 mpg? - BMW Forum - BimmerWerkz.com
Old 12-31-2003, 04:12 AM   #1 (permalink)
juanfan is an unknown quantity at this point
Hi
On average what does a BMW M3 do on unleaded petrol in the UK in everyday use/motorway......etc
juanfan is offline   Reply With Quote
Old 12-31-2003, 12:10 PM   #2 (permalink)
cam540 is an unknown quantity at this point
not sure if this helps but I average 22.2 miles a gallon here in the states.
<img src='http://people.albion.edu/dbc10/images/w04.gif' border='0' alt='user posted image' />
<a href='http://http://www.licenseschoolusa.com/real-estate-book.php' target='_blank'>Real Estate Books</a> | <a href='http://www.spotya.com' target='_blank'>Spotya! Quick Cash</a> - Short term cash loans for online shopping.
<a href='http://www.licenseschoolusa.com' target='_blank'>Real Estate License</a> | <a href='https://www.linkedin.com/profile?viewProfile=&key=1629532' target='_blank'>My LinkedIn Profile</a> - Contact me
cam540 is offline   Reply With Quote
Old 01-03-2004, 08:28 PM   #3 (permalink)
F1 Nut is an unknown quantity at this point
Send a message via AIM to F1 Nut
Also don't forget that the gallon in the UK is bigger then the gallon in the US....sorry to add more confusion but I thought you should know.
F1 Nut is offline   Reply With Quote
Old 01-04-2004, 08:13 PM   #4 (permalink)
KingScare's Avatar
Car: 98 M3
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
Depending how you drive it...
If you constantly/more or less shift through the gears (i.e: accelerating and seeing that needle dissapear over 30 in the "gas consumption" (for lack of actual term) dial.) Then you'll be seeing that other gas tank needle go down fairly quickly.
Though, if you take it easier...and try to resist all the "enthusiastic driving" temptations you might encounter. It's not so bad. Good size tank too.
If you want, I could closer observe my own consumption.
It'll be in Canadian dollars and metric system though...
I WON'T CONVERT IT!!!! YOU CAN'T MAKE ME!!!!
KingScare is offline   Reply With Quote
