Another Oil to Contemplate! - BMW Forum - BimmerWerkz.com
Old 05-09-2008, 10:29 AM   #1 (permalink)
Herbjenssen is on a distinguished road
I'm a new owner of a 02 M3 and have been reading about the Castrol oil 10W60 that was recommended by BMW after the rod bearing recalls on the M3's.
I used to be a Amsoil guy but when I had some work done on an older Vette
the mechanic had to drain my Amsoil that I had just put in about 2 weeks prior.
Anyway, he informed me that he uses Shell Rotella T 5W40 in all his race engines and he really likes it.
I said isn't that diesel oil? He said yes and told me that a few years back all automotive oils were required to remove some additives that really prevented wear and other things, maybe sludge? I don't remember!
That's the reason he started using it. It's the full synthetic Rotella T.
I went home and called Amsoil and asked if this was true about the removal of additives and was informed it was true.
I called the guy back at Thunder Racing in Baton Rouge, La and told him to fill the car up with Rotella T.
I purchased 4 cases with 4 gallons to a case from an oil distributor for $190.72 which comes to $3.01 a quart.
Thunder Racing is a well known shop and is mentioned in automotive magazines.
My M3 just went out of the warranty that BMW gave the M3's after the bearing change and I do believe I'm going to use that oil in the M3 unless someone can convince me otherwise.
I just thought I would throw this out there for food for thought.
Later
Herb
Herbjenssen is offline   Reply With Quote
Oil Change/oil Inspection Light Reset 2002 525i mssoetaert 5-Series (E12,E28, E34, E39, E60) 5 08-08-2005 05:42 PM
Too Much Oil, Wrong Oil, Gas Leak? yammahamma 3-Series (E21, E30) 4 07-26-2005 06:20 PM
Yellow Oil Light On, But Oil Level Is Perfect bbensten 3-Series (E46, E90) 8 02-28-2005 07:57 AM
Oil Smells Like Gas - Oil In Sprk. Plg#2 jkh2828 3-Series (E36) 2 01-21-2005 07:18 AM
reseting oil bar after oil change on e36 LIMaxin 3-Series (E36) 6 08-26-2004 11:42 PM
