if you suspect fuel pump problems, here's what you can do:
spray some brake cleaner into the throat of the throttle body and start ur car... if it fires up and then eventually dies; then yes, it is a fuel problem.
If... after you have sprayed it two or three times and it still won'teven sputter, then your problem is electrical.
Have fun and Good Luck.
