95 M3 Clutch Issues - BMW Forum - BimmerWerkz.com
Old 02-18-2009, 02:14 PM   #1 (permalink)
nam328i is on a distinguished road
95 M3 Clutch Issues
I own a 95 m3 and unfortunately I wasn't able to store it indoors for the winter months here in Pittsburgh. It sat for approximately 5 weeks and I went to fire it up the other day. The battery was dead so I was able to jump it and let it idle for about 30 min.
Before starting it, I stepped on the clutch and it dropped to the backstop with no resistance. I fired it up with the shifter in neutral and even after letting it warm up, the same thing happens. After it hits the floor, I have to pull it back to resting position and it will stay there, but if there is any pressure on it from my foot, it just drops and on and on.
I spoke to a mechanic and he said that possibly the clutch slave cylinder is empty of fluid. I was wondering if anyone else has ever encountered this problem and what the possible causes may be. If it is the lack of fluid in the slave cylinder, where is the reservoir, and what type of fluid should be used?
I looked under the car and because my driveway was icy, it was hard to tell if there had been a leak. Can anyone advise?
nam328i is offline   Reply With Quote
Old 02-18-2009, 02:33 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
sounds like the fluid drained out... check your brake fluid level(I believe it uses the same container and use brake fluidthen find where it is leaking!
1992 318i Coupe parts car
I am Captain Obvious
Old 02-18-2009, 03:42 PM   #3 (permalink)
PrInG's Avatar
Car: 95 Dakar Yellow M3, 00 1.8T VW GTI
PrInG has a spectacular aura aboutPrInG has a spectacular aura about
Send a message via AIM to PrInG
I've never had this problem with my 95 M but My eclipse has a hell of a time holding clutch fluid in the winter time. Its fine when the weather is warm but not when it is cold. I'd almost say that is your problem for sure. Get a manual(haynes,chilton) what have you. It will save you time and headache. And I believe apline is right I think it is just regular brake fluid, thats what i use in the clipser. I've never had the problem with my M so i can't give you further instructions there. good luck..
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline   Reply With Quote
Old 02-19-2009, 12:44 PM   #4 (permalink)
Clutch Slave Cylinder
If you wind up needing a new clutch slave, we sell it for $49. We also have a certified technician on duty to answer any calls if you need help pinpointing a problem. Best of Luck!
Phone#: 877-634-0063
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
starting issues 325ikid 3-Series (E46, E90) 1 09-27-2008 07:12 AM
A/c Issues PR bimmer 3-Series (E46, E90) 1 02-27-2008 02:29 AM
Battery Issues mike_sh45 1,6,7,8 - Series and Mini Cooper 7 03-30-2005 05:41 AM
96 318i AC Issues? BMWBoi 3-Series (E36) 1 07-14-2004 12:20 PM
More AC issues wulley1 3-Series (E36) 13 05-28-2004 06:31 PM
