Im using water/alcohol injection tapped into my 2.5L washer fluid resovoir. I use a 50/50 mix of alcohol and distilled water. It seems I have to refill my resovoir every 2-4 days. My cars is drinking more alcohol than me!!! I cant seem to find any leaks. Anyone know if this is normal?
It may be a little close to the same, but a friend of mine has a 68 firebird that is blown and alcohol injected and he said it takes twice the alcohol as the cam2 he was running. I am guessing thats where the extra power comes from.
The thing holding you back from installing the larger water tank is space... if you can find space... you can do it... all the hook ups should be the same. Connections I mean.
Any idea how much the 5.0L tank costs? I want to see what it looks like. I have some space to use in my engine bay and could probably just drill it down dependign on shape.
If the fluid tank is made out of plastic or resin, and you had something just barely blocking it from installation, you could heat it up and reshape it to make it fit.
__________________ LongHairedHippy: Just let him die out. The odds are on that he won't reproduce, so the problem will take care of itself
