» Sponsors
» Sponsors
Go Back   BMW Forum - BimmerWerkz.com > General Category > Forced Induction
Forced Induction Talk about turbo and superchargers.
Old 11-11-2007, 11:53 PM   #1 (permalink)
Photos: 0
CosmosBlk97 is on a distinguished road
GT 28 Turbo on stock S52 M3 10k motor 8psi
Before I start this I have posted in forced induction as well just hoping for more helpful positive replys by people w/ experience on the field.
I have '97 E36 M3 w/ new motor on it. At this moment will go with GT28 BB turbo FMIC at 8 psi stock motor and compresion. From what i know S52 comes w/ forged steel rods and forged crank. sounds like the only weak spot is cast aluminum pistons. Do you know HOW MANY HP they are good for?!!
How many psi i can do on GT28 stock motor safe?!!! With or without methanol injection
Winter time i will pull motor and do custom low compresion forged pistons and GT40 or GT42. Im not sure if im going to change rods because i have compared stock S52 to forged aftermarket I beam and the stock looks very beefy and the H beam design is very strong. From what i know stock is just as strong as aftermarket, just heavier so slower rev...
Im NOT LOOKING TO go too wild w/ this car so I want to keep it in 400-550 range depending on boost
I will be very happy to get a reply by people done this before. Will be nice to hear from people running similar setups in a long run. I will appreciate any Positive input !!! Thanks
CosmosBlk97 is offline   Reply With Quote
Old 11-12-2007, 09:58 AM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
Swap rods with an S50 motor, they're noticeably beefier.
Lindsay fan club member.
Old 11-12-2007, 01:31 PM   #3 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 1
I'm going to recommend you not go with a gt28r, but rather consider at the minimum a gt30 with your ideal being a gt35r.8 psi is fine for the stock compression and motor as long as you have it tuned properly.
Yes on rods and crank. Everything in the motor is pretty good for up to 450+ rwhp reliably. Some swear by the necessity to do beefier rods and low comp pistons. The majority have safely done a thicker headgasket with ARP studs in order to lower the compression ratio.
I wouldn't push past 9 psi borderline on the stock compression stock motor. You neeed to install a thicker headgasket and stronger studs in order to really go above that. And do not look at meth injection as a tool to push your stock motor.
The stock are very strong, but many people playign with gt40/42's generally do them just in case. I've defintely seen quite a few 450+ rwhp setups send rods through the block.
Actually, I would go with the Non-Vanos rods from the 92 3 series. Although aftermarket rods are probably better in his case.
Old 08-04-2008, 02:01 PM   #4 (permalink)
inthecrosshairs's Avatar
Photos: 0
inthecrosshairs is on a distinguished road
8psi from a gt28 is honda 1.5l territory. I've gone that route. That psi, from that small of a turbo is going to be painfully inefficient and a waste of money. You are going to have to see well over 20psi to see 450whp with that turbo, and you will be maxing it out, if you even hit your goal. You are better off with a much larger turbo.
450whp is easily achieve able on a completely stock engine, too bad you have the shoddy headgasket eating motor. Run to 500whp, blow out the headgasket, sell it to some dousche who wants n/a power, buy an m50/m52 and enjoy 450whp daily.
inthecrosshairs is offline   Reply With Quote
vB code is On
Turbo M3 vs. 350Z 100 shot & 2 stock 350Z's (long write-up) ///M Power Driving Tales 9 12-13-2006 10:49 PM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
