blow off valve - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > General Category > Forced Induction
Forced Induction Talk about turbo and superchargers.
Old 01-14-2008, 08:55 PM   #1 (permalink)
revharde30 is on a distinguished road
blow off valve
can u put one on a super charger
revharde30 is offline   Reply With Quote
Old 01-14-2008, 09:24 PM   #2 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
centrifugal superchargers usually run a recirculation valve...or even the blow off valve...blow off valves don't function as well as recircs on turbo/centrifugal superchargers but they "sound cool"
but as far as screw type superchargers you dont need one...the second you let off the throttle the supercharger slows down...no issues of back spooling the supercharger...
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 01-14-2008, 09:43 PM   #3 (permalink)
i got a g60 and im putting a motor in it and i want the cool sound
Old 01-14-2008, 09:57 PM   #4 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
RICE ALERT!!!!!!!!!
DIRTE30 is offline   Reply With Quote
Old 01-15-2008, 12:16 AM   #5 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
^lol yeah..... there for turbos if you want that sound turbo the thing....
1992 318i Coupe parts car
I am Captain Obvious
Old 01-15-2008, 02:56 PM   #6 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
your best bet with the supercharger is a bypass valve instead... technically you could run an atmospheric blow off valve but im pretty sure you will lose power as a result...
Old 01-15-2008, 03:05 PM   #7 (permalink)
gotKRAUT's Avatar
corrado G60? with a G Lader supercharger there is no need for a blow off valve...come on man...thats just silly
Kyle Sutherland
1995 BMW 540i/6:
Old 01-15-2008, 06:19 PM   #8 (permalink)
yea
Old 01-15-2008, 07:14 PM   #9 (permalink)
gotKRAUT's Avatar
moved to forced induction forum as it was not E30 specific
Kyle Sutherland
1995 BMW 540i/6:
Old 01-16-2008, 03:06 PM   #10 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Not true at all. Venting to atmosphere or recirculating should be based on whether its a blow through or pull through forced induced setups.
Old 01-16-2008, 03:12 PM   #11 (permalink)
gotKRAUT's Avatar
it really shouldn't matter, its better to keep as much air circulating through the turbo as possible to keep it spooling, where as with a BOV you are just venting the boost air to atmosphere and not sending it back through the turbo...what am i missing?
Kyle Sutherland
1995 BMW 540i/6:
Old 01-16-2008, 04:10 PM   #12 (permalink)
gotKRAUT's Avatar
After re-reading what you said, I figured out what you meant. As far as AF mixtures and what not go, you are correct. In a draw through setup you should run a recirc as the computer has already calculated for that much Air/Fuel. Although, I'm starting to think you miss understand the purpose of the recirc....
First there were recirc valves. BOV's came way later because they sound cool. In all reality, regardless of draw through or blow through (I'm guessing you mean MAF location) you will still keep the turbo spooling faster if you take the boost pressure from between the throttle body and turbo, and put it back before the turbo. The turbo will continue spinning faster and for longer than if you were to just take that boost pressure and release it to atmosphere.
Granted, a BOV is better than nothing...as that throttle closes, the pressure builds until the turbo stops or even back spools which = teh bad...
Conclusion: Recirc > BOV > Nothing
Kyle Sutherland
1995 BMW 540i/6:
Old 01-17-2008, 03:21 AM   #13 (permalink)
Retired administrator
triggrhaapi's Avatar
Uhh... no. The way it affects backspooling is the same either way. I believe you are referring to a common tuning issue whereby blowing to atmosphere causes certain tuning setups to go rich when venting to atmo and using a draw through (not pull through) MAF system. This happens because air is drawn through the MAF and metered, which adjusts the fuel injector duty cycle and provides fuel to mix with air that ends up getting wasted to atmosphere.
Addicted to Speed Since 1997
Old 01-17-2008, 07:28 AM   #14 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
with your corrado G60 do you plan on rebuilding the supercharger a lot? With the supercharger you can get the cool whiiiiiiinnne sound, ive heard a bunch of vw's with superchargers, mainly 2 liter 8v's though.
Old 01-17-2008, 10:06 AM   #15 (permalink)
gotKRAUT's Avatar
Thanks for giving the same answer i gave...
the GLader already makes that sound a little bit...swap out the GLader for a bahn brenner twin screw...that setup sounds MONEY....loudest SC evAr...so hawt...
Kyle Sutherland
1995 BMW 540i/6:
The Frankenmotor Project: Step One triggrhaapi FAQ's and DIY's 39 03-15-2007 11:33 AM
Replacing 540 crankcase ventilation valve? beachcomber_bill 5-Series (E12,E28, E34, E39, E60) 2 07-16-2006 05:55 PM
4cyl valve adjustment?? Moosepuck 3-Series (E21, E30) 22 05-30-2006 07:06 PM
Blow Off Valve JAX 3-Series (E36) 2 10-28-2004 09:04 AM
Blow Off Valve matt325is 3-Series (E36) 31 10-22-2004 10:01 AM
