» Sponsors
» Sponsors
Go Back   BMW Forum - BimmerWerkz.com > General Category > Forced Induction
Forced Induction Talk about turbo and superchargers.
Old 01-17-2008, 01:04 PM   #16 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 1
Originally Posted by triggrhaapi
Uhh... no. The way it affects backspooling is the same either way. I believe you are referring to a common tuning issue whereby blowing to atmosphere causes certain tuning setups to go rich when venting to atmo and using a draw through (not pull through) MAF system. This happens because air is drawn through the MAF and metered, which adjusts the fuel injector duty cycle and provides fuel to mix with air that ends up getting wasted to atmosphere.
Sorry about that. I'm just so used to the standard question of whether a person can vent to atmo if their air is metered. For some reason the thought of backspooling wasn't even crossing my mind. Just real confused lately, might be all the drugs.
Old 01-17-2008, 01:05 PM   #17 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
Photos: 0
i like how you replied to jasons and not mine and i said the exact same thing first
Kyle Sutherland
"PirateKrautFixieRidinEuroDestroyingRestoring BeerWineScotchRumDrinkingLovingMarriedMan"
M50TU TURNER TREEHOUSE HID LSD KONI BILSTEIN OZ IE ROGUE HELLA MAGNAFLOW MOMO DINAN CORBEAU K&N BLAUPUNKT
gotKRAUT's M50tu Build/Swap Thread
gotKRAUT's E30 Trailer Thread!*Updated 01/30/2010*
Old 01-22-2008, 04:00 PM   #18 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 1
Yeah I know you did. I thought I apologized and explained my confusion to you on AIM. I'm all confused these days. Please take notice of the quote in my signature.
Old 06-07-2008, 09:35 PM   #19 (permalink)
Photos: 0
jonas001 is on a distinguished road
Wink Its all in the tuning
If you want to run a blow off on a turbo or even supercharged car, you would need a stand alone, speed density type of engine management that uses a MAP sensor which measures manilfold vacuum, an AIT sensor that measure Air temp coming into the motore to measure how much air is coming into (car computer takes these three numbers along with predermined VE number (the part we adjust during tuning) to calculate how much air to add.
99% of cars today run a MAF sensor instead. which directly measures air mass going into the motor typically by a heated element, moving trap door or some other method. These systems are much more accurate than speed density as they adjust automatically to weather by design since they measure the amout of air directly and not indirectly like speed density hence the reson the OEM uses them. More accurate readings means less emissions and a smoother running car.
Back on topic
On a forced induction car. If the MAF sensor is in front of the Turbo/Blower as is the typical case then running a Blow off valve will trick the car to think it has more air than it really is injesting during shifts and light throttle when it is blowing off. This is because the blow off valve dumps air already measured by the maf sensor into the atmosphere, the car assumes its in the motor and adds extra fuel which causes this very rich fuel mixture. The car will sputter and spit a little black smoke out the tail pipe or even a backfire (running rich) between shifts or a mid throttle just as you go into boost. In extreme cases it can be so rich that it stalls the car.
Most aftermarket engine management systems use the speed density system to measure air because it is soo much cheaper and easier to install to any type of motor. A maf typically is very specific to a particular model motor and can't be easily adapted for many cars. You can use universal MAP and air temp sensors that can be attached very easily to just about any type of engine. MAP needs a vaccume line out of the intake manifold and a IAT sensor can be easily attached via a small hole in the intake tract of the car to measure incoming air temp.
If you ever seen an Mitsu evo at night with alot of boost, no Catalitic Converters and a blow off valve you may know what I'm talking about, you can even see flames shoot out the tailpipe at night . It might look and sound cool but they are paying with it via drivability. I had and tuned Evos, awsome car for the money! A poor man's porche
I have been tuning cars for quite some time now albiet not a Bimmer. If you have any questions about forced induction, tuning, or modifying cars in general Id love to try to help.
BTW u can get a greddy type RS blowoff valve without the horn attached and use it as a recirc valve for the blow off sound. Thats what we evo guys did
jonas001 is offline   Reply With Quote
Old 06-12-2008, 02:43 PM   #20 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 1
Just about all BOV's out thre today have an option for a recirculation fitting, not just Greddy.
Old 06-13-2008, 02:44 AM   #21 (permalink)
denyo77's Avatar
Car: 88 325i e30 Touring
Photos: 1
denyo77 is on a distinguished road
the Corrado G60 is already cool enough, in my opinion
denyo77 is offline   Reply With Quote
vB code is On
The Frankenmotor Project: Step One triggrhaapi Member's DIY Projects 39 03-15-2007 11:33 AM
Replacing 540 crankcase ventilation valve? beachcomber_bill 5-Series (E12,E28, E34, E39, E60) 2 07-16-2006 05:55 PM
4cyl valve adjustment?? Moosepuck 3-Series (E21, E30) 22 05-30-2006 07:06 PM
Blow Off Valve JAX 3-Series (E36) 2 10-28-2004 09:04 AM
Blow Off Valve matt325is 3-Series (E36) 31 10-22-2004 10:01 AM
