tie rod? - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 06-08-2008, 10:58 AM   #1 (permalink)
Car: 2000 BMW 323i
ceciliaj is on a distinguished road
Send a message via AIM to ceciliaj
tie rod?
when i start my car it makes this rubbing sound,when i turn the wheel it sounds like something rubbing on a tire..happens when i turn the wheel in either direction any ideas? also had airconditioning recharged but still isnt cold.
ceciliaj is offline   Reply With Quote
Old 06-08-2008, 11:31 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
perhaps you are using out of specification tires that are too big for your wheelwells?
Tirerods are not your problem :-)
a/c recharge with out vacuuming your system, may have caused your "isn't cold" problem. Proper way is to have a tech, evacuate and vacuum test your A/C system before you introduce your freon.
Old 06-08-2008, 12:20 PM   #3 (permalink)
Car: 2000 BMW 323i
thanks forthe info.maybe i didnt describe the sound good enuf.when i turn the wheel it seems kinda hard..the sound is like a door reaking sound or when a spring is gonna break..
Old 06-08-2008, 12:56 PM   #4 (permalink)
Have you checked your power steering fluid level? If it's low, that's a sound you would hear while turning the wheel.
Old 06-08-2008, 03:41 PM   #5 (permalink)
Cool
ahhh.. take witeshark's advise and check power steering fluid ;-)
Old 06-08-2008, 04:45 PM   #6 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
yeah sounds like power steering... it is like a squeeling when you turn the wheel... turn the car off and try to turn the wheel if it goes away it is the Power assist Pump or just low fluid......
1992 318i Coupe parts car
I am Captain Obvious
Tie rod replacement DFL 3-Series (E36) 18 11-30-2007 03:15 PM
bent tie rod nelzabob 3-Series (E36) 0 03-03-2007 12:18 PM
Control Arm Or Tie Rod dvmotorsports 3-Series (E36) 5 06-25-2005 09:23 PM
Tie Rod Alignment Problem. dopeyx27 3-Series (E36) 9 05-02-2005 10:56 AM
Inner Tie Rod Ends Tadao 3-Series (E21, E30) 0 01-10-2004 03:36 PM
