Restore Your Scratched Up BMW Dash Console to Factory New for only $6! Pictorial DIY - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 04-01-2010, 03:08 PM   #1 (permalink)
quality
Delmarco's Avatar
Cool Restore Your Scratched Up BMW Dash Console to Factory New for only $6! Pictorial DIY
So after my last retrofit project of installing the DCT Sport Shifter, I found that the new knob made the rest of my console look extra old and worn. My console cubby doors had the usual BMW rubber coating peeling and scuff marks from years of use.
So I went online and found that these things are about $50 (used on ebay) to $150 (brand new at BMW dealership) to replace.
I also came across many DIYs that showed folks using black spray paint on the doors and a few showing the scrubbing off of the worn out rubber coating completely to reveal the bare plastic underneath. I also saw other suggestions for plasti-dip and a DIY for using plasti-dip on the cupholders/armrest.
So long story short I became interested and got a can of Plasti-Dip at my local Home Depot for $5.98 (the paint/home/hardware sections at your local Kmart, Walmart, Target, Sears, etc... will have this or else go find it at Autozone, Pepboys, or any good Hardware store ) and I proceeded to do this DIY.
So far the Black color is the only color that Plasti-Dip seems to come in and I do wish they had BMW hellbeige/tan, or even gray for our non-black cupholders center armrest console sections.
This DIY is easy and the results are astonishing and makes you wonder why people buy these trim pieces out of Salvage Cars for tons of money to replace their worn ones when just a $6 can of Plasti-dip will make the trim new again.
The only tools I used were a razor blade and scotch tape that I found around my apartment. Screw driver and a T10 will aslo be needed to remove the trim pieces. I also used fine 150 grit sand paper on my steptronic plate trim, but found it was not necessary if your trim isn't super pitted and/or you are using more than 2 coats.
The most important tool will be your patience. Plasti-Dip takes a long time to dry-even when it feels dry to the touch-it will be moist and soft for up to 4-5 hours after the last coat goes on and your final coat will easily scratch and scuff if you rush to put it back in your car.
Also waiting 30 full minutes or more between coats is highly recommended. Don't ask me how I learned all this but I learned it the hard way.
Said and done, if you do mess up and the coating comes out wrong you can easily peel the coat right off and start over again. Plasti-Dip isn't super permanent like paint but more like liquid rubber.
Start by removing your console trim and gear plate. This is basic 101 DIY but the pictures below should prevent you from running into any surprises.
NOTE: If the pictures don't all load here is the link to the album:
ImageShack Album - 39 images
Old 04-01-2010, 03:08 PM   #2 (permalink)
quality
Delmarco's Avatar
Old 04-01-2010, 03:11 PM   #3 (permalink)
quality
Delmarco's Avatar
Old 04-01-2010, 03:15 PM   #4 (permalink)
Wow, quite cool!
Old 04-01-2010, 03:44 PM   #5 (permalink)
quality
Delmarco's Avatar
Originally Posted by witeshark View Post
Wow, quite cool!
Thanks buddy.
Originally Posted by Albobmw View Post
Nice job. What grain of sanding paper is adequate in removing the old coating?
I used fine 150 grain to lightly sand it down. But if you want to completely scrub all the old rubber away get a heavier than 150 grain.
Originally Posted by neil1138 View Post
I like how you didn't even bother stripping the original crumbling coating, you just painted over it
lol.:craig:
I din't have time for all that. after I did the step plate and started sanding that trim I realized that sanding to smooth out the lumps was a long tedious process relative to the spraying part of the DIY so I could'nt imagine the time I would have put into sanding off all the old rubber coating on the door.
Also I realize if you are using more than 3-4 coats it just covers over any rough spots.
The important thing is to make sure you are spraying a clean/oil free surface!
Actually Neil I think one of your old pictures or posts may have inspired me to do this. Wasn't it you that used Plasti-Dip or black paint on something or the other? I'm pretty sure but if so, much props to you man. up:
One last thing for everyone. Plasti-Dip is NOT Paint. Don't go into this thinking you are repainting the trim. You are in fact just coating it over with a rubberized liquid. Think of chocolate covered starwberries.
Old 04-01-2010, 04:23 PM   #6 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Dude. This is clever. I would have just bought a new car
Turkey Fleet Bond Holder
Old 04-01-2010, 04:57 PM   #7 (permalink)
quality
Delmarco's Avatar
lol. Okay Donald Trump...ahem...I mean Daniel Trump.
Old 04-01-2010, 05:28 PM   #8 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Excellent DIY.
That said, are the e36 plastics really that prone to wear? I mean every single piece of plastic in my e36 looks like new and e36 aren't exactly built like tanks compared to older BMWs.
Old 04-01-2010, 09:55 PM   #9 (permalink)
german-speed-demon's Avatar
While i may not like you on some days, i can't argue with the level of DIY's you put together.
Excellent work sir.
R.I.P fast 6
Old 04-02-2010, 12:03 AM   #10 (permalink)
quality
Delmarco's Avatar
Originally Posted by Torque View Post
Excellent DIY.
Yeah my E36 (rip) had much better quality interior plastic than the E46.
Every surface in the e46 literally wears away because BMW used some sort of soft rubber coating on the surfaces in the E46. So after 4 -5 years it begins peeling away like dried glue.
I hear the 2010 E90 lci are even more horrible since BMW downgraded all the standard parts of the 3 series starting in models built from 9/09.
One guy on e90post who went from E30 to E36 to E46 to a 2007 330i and now 2010 335i said it was the worse interior built quality BMW he has ever sat inside.
BMW took away the seat back nets, the glove box flash light and power outlet, the ashtrays/console pockets lost their lids, the hood lid lost the soft sound proofing lining, the seats come with less cushion stuffed in them and the headrests don't move up/down...etc...
considering his new BMW 335i cost $50,000+
Old 04-02-2010, 08:07 AM   #11 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Del, you are the king of a detailed DIY project. Now can you come up with a really simple Bluetooth & Ipod upgrade for a 2000 E38 with Navigation and OBC?
Hopefully you'll starting taking requests.
Old 04-02-2010, 08:16 PM   #12 (permalink)
Mr. Clean
BimmerE39's Avatar
Sad, but not a surprise either. Almost every manufacturer is finding ways to cut manufacturing cots at every level and it's a trend happening everywhere in manufacturing besides the car world.
It's amazing how manufacturers cheapen everything they do and still find a way to justify jacking up the price.
Old 04-07-2010, 02:16 PM   #13 (permalink)
quality
Delmarco's Avatar
Originally Posted by ZZen330 View Post
Hmm..but the rough edges around the shifter plate indicators doesn't look good. .
Oh yeah I fixed the shifter plate. The same thing was bothering me too.
What had happened was I put too many coats on the thing. I peeled off all the original plasti-dip, sanded the plate better and re-coated it with only one coat and it looks fab now!
BMW E46 Integrated Bluetooth and Voice Command for Less than $100 Pictorial DIY Delmarco FAQ's and DIY's 16 11-20-2010 11:55 PM
BMW E46 Sedan Rear Armrest Console Cup Holder OEM Modification Pictorial DIY Delmarco FAQ's and DIY's 7 02-14-2010 01:23 AM
Pictorial DIY BMW Rear Armrest & Cup Holder Console LED Lights (Part 3) Delmarco FAQ's and DIY's 2 08-21-2008 01:56 AM
Pictorial DIY BMW Sunglasses Holder Space & Console LED Lights (Part 2) Delmarco FAQ's and DIY's 7 08-20-2008 11:37 AM
Pictorial DIY Installation for BMW Cup Holder and Center Console LED Lights! Delmarco FAQ's and DIY's 13 08-14-2008 10:28 PM
