Pumping gas. - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 05-01-2008, 10:06 AM Thread Starter
thorconstr is on a distinguished road
Pumping gas.
I think you will find this of interest!
> ?TIPS ON PUMPING ?GAS
> I don't know what you guys are paying for gasoline.... but here in
> California we are also paying higher, up to $3.96 per gallon. But my
> line of work is in petroleum for about 31 years now, so here are
> some tricks to get more of your money's worth for every gallon..
> Here at the Kinder Morgan Pipeline where I work in San Jo se, CA we
> deliver about 4 million ga llons in a 24-hour period thru the pipeline.
> One day is diesel the next day is ?jet fuel, and gasoline, regular
> and premium grades. We have 34-storage tanks here with a total
> capacity of 16,800,000 gallons.
> Only buy or fill up your c ar or truck in the early morning when the
> ground temperature is still cold. Reme mber that all service
> stations have their storage tanks buried below ground. The colder
> the ground the more dense the gasoline, when it gets warmer gasoline
> expands, so buying in the afternoon or in the evening....your gallon
> is not exactly a gallon. In the petroleum business, the specific
> gravity and the temperature of the gasoline, diesel and jet fuel,
> ethanol and other petroleum products plays an important role.
> A 1-degree rise in temperature is a big deal for this business. But
> the service stations do not have temperature compensation at the pumps.
> When you're filling up do not squeeze the trigger of the nozzle to a
> fast mode. If you look you will see that the trigger has three
> (3)stages: low, middle, and ?high. In slow mode you should be pu
> mping on low speed, thereby minimizing the vapors that are created
> while you are pumping. All hoses at the p ump have a vapor return. If
> you are pumping on the fast rate, some other liquid that goes to
> your tank becomes vapor. Those vapors are ?being sucked up and back
> into the underground storage tank so you're getting less worth for
> your money.
> One of the most important tips is to fill up when your gas tank is
> HALF FULL or HALF EMPTY. The reason for this is, the more gas
> you have in your tank the less air occupying its empty space.
> Gasoline evaporates faster than you can imagine. Gasoline storage tanks
> have an internal floating roof. This roof serves as zero clearance
> between the gas and the atmosphere, so it minimizes the evaporation.
> Unlike service stations, here where I work, every truck that we load
> is temperature compensated so that every gallon is actually the
> exact amount.
> Another reminder, if there is a gasoline truck pumping into the
> storag e tanks when you stop to buy gas, DO NOT fill up--most likely
> the gasoline is being stirred up as the gas is being ?delivered, and
> you might pick up some of the dirt that normally settles ?on the
> bottom. Hope this will help you get the most value for your ?money.
> DO SHARE THESE TIPS WITH OTHERS!
> WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
> Gas rationing in the 80's worked even though we grumbled about it.
> It might even be good for us! The Saudis are boycotting American
> goods. We should return the favor.
> An interesting thought is to boycott their GAS.
> Every time you fill up the car, you can avoid putting more money
> into the coffers of Saudi Arabia. Just buy from gas companies that
> don't import their oil from the Saudis.
> Nothing is more frustrating than the feeling that every time I fill-up
> the tank, I am sending my money to people who are trying to kill me, my
> family, and my friends.
> I thought it might be interesting for you to know which oil
> companies are the best to buy gas from and which major companies
> import Middle Eastern oil.
> These companies import Middle Eastern oil:
> Shell........................... ?205,742,000 barrels
> Chevron/Texaco......... ?144,332,000 barrels
> Exxon/Mobil............... ?130,082,000 barrels
> Marathon/Speedway... ?117,740,000 barrels
> Amoco............................62,231,000 ?barrels
> Citgo gas is from South America - a Dictator who hates Americans. If you
> do the math at $30/barrel, these imports amount to over $18 BILLION!
> (oil is now $90 - $100 a barrel
> Here are some large companies that do not import Middle Eastern
> oil:
> < BR>> Sunoco..................0 barrels
> Conoco..................0 barrels
> Sinclair..................0 barrels
> BP/Phillips.............0 barrels
> Hess.............. ........0 barrels
> ARC0.....................0 barrels
> If you go to Sunoco.com <
http://sunoco.com/%3E; , you will get a
> list of the station locations near you.
> All of this information is available from the Department of Energy and
> each is ?required to state where they get their oil and how much
> they are importing.
> But to have an impact, we need to reach literally millions of gas
> buyers. It's really simple to do.
> Now, don't wimp out at this point.... keep reading an d I'll explain
> how simple it is to reach millions of people!!
> I'm sending this note to abo ut thirty people. If each of you send it to
> at least ten more (30 x 10 = 300)...and those 300 send it to at
> least ten more (300 x 10 = ?3,000) .. and so on, by the time the
> message reaches the sixth ?generation of people, we will have
> reached over THREE MILLION consumers ?!!!! !!! If those three
> million get excited and pass this on to ten friends each, then 30
> million people will have been contacted!
> If it goes one level further, you guessed it ..... THREE HUND RED
> MILLION PEOPLE!!! ?
> Again, all you have to do is send this to 10 people. How long would all
> that take?
thorconstr is offline
post #2 of 9 (permalink) Old 06-05-2008, 12:51 AM
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
yup ive seen this. trick is to wake up around 6 in the morning. haha joking. but really, all good tips. real help would be to get gas price down!! either way burn gas always and forever. in 30 years when everyone is in electrics and hybrids ill still be enjoying gas. and hopefully not at that much of an inflated price compared to now!!!!
pinnaclebass is offline
post #3 of 9 (permalink) Old 06-05-2008, 01:43 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
.... I fill up at about 7am and dont let it get under 3/4- 5/8 a tank.... it is to hide what i'm actually spending on gas....
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #4 of 9 (permalink) Old 06-05-2008, 11:24 PM
ya i should try that method, haha.
post #5 of 9 (permalink) Old 06-06-2008, 02:57 PM
it works! putting 20 in every couple days looks better in your head then 40 or 50 half a offen...
post #6 of 9 (permalink) Old 06-06-2008, 03:09 PM Thread Starter
I wonder what would happen if everyone in the USA used the companies that weren't mid eastern for one week! That would be one hell of a dollar amount loss! I bet that they would look at things a bit differently!
post #7 of 9 (permalink) Old 02-13-2009, 09:11 PM
jmo69's Avatar
jmo69 is on a distinguished road
I realize temperature affects volume, but I don't think the temperature of the fuel in that underground tank will rise that fast. Ground temperature is pretty constant once you get down a few feet. Most of the stations around here have canopies over the pump islands that shade most of the area where the tanks are buried. I think the temp change is greater in your tank than in the storage tank, just my $.02.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline
post #8 of 9 (permalink) Old 03-13-2010, 06:45 PM
ebida3's Avatar
ebida3 is on a distinguished road
Good info. I will be aware of my pump habits!
ebida3 is offline
post #9 of 9 (permalink) Old 03-13-2010, 11:02 PM
1LOBOSS's Avatar
1LOBOSS will become famous soon enough 1LOBOSS will become famous soon enough
Actually Canada exports more oil to the USA than any other country in the world. Surprised? It's a fact.
I am a jolly green giant in the land of little people
1LOBOSS is offline
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
It smells like gas. Leaky gas filler cap. bymerdynamics 3-Series (E21, E30) 2 12-19-2006 12:01 AM
gas gas gas! Andres823 3-Series (E46, E90) 5 08-05-2006 12:47 AM
1998 328i - gas fouled plugs & gas smell out of tailpipes bpetkovic 3-Series (E36) 1 12-04-2005 08:10 PM
Oil pump is pumping engine out of my car! M5power 5-Series (E12,E28, E34, E39, E60) 9 03-08-2004 06:07 PM
good gas & bad gas? bmw_m3power 3-Series (E36) 5 12-27-2003 12:54 AM
