The Frankenmotor Project: Step One - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 04-02-2006, 05:12 PM   #1 (permalink)
Retired administrator
triggrhaapi's Avatar
So I finally got to work on rebuilding my S50 cylinder head, I figured you guys might want to have a look and see how it's going. This will give you a basic understanding of how to remove bent valves from a cylinder head, and how to inspect valves for bending and inspect valve seats for gaps, nicks and other imperfections that will potentially cause the valves to not seal properly.
First off, allow me to introduce you to the pre- procedure to get up to this point. In order to remove valves, the cylinder head must first be removed from the car, this should be done according to the procedure in the Bentley Manual. If you can't follow that procedure, do not attempt this project. Find a reputable dealer or shop to do it for you.
Once the cylinder head has been removed, remove the camshafts according to this procedure. Again, if you believe you are unable to follow that procedure, do not attempt this project. That procedure is quite delicate and if performed improperly could crack and potentially destroy your camshafts. The E36 camshafts are hollow to reduce rotational mass, but that also means that they are not as strong as they may seem. The force that the valvesprings put on the camshaft could easily break it.
Once the camshafts are out, remove the cam carriers, taking care not to allow the tappets to fall out of their bearings. Once that is done you should have exposed valvesprings. To continue with this project you will need a valve spring compressor that is designed to work on DOHC cylinder heads. most any tool will work, and the one I purchased cost me around $35.
The tool will look like this:
Take care to attempt to grab the spring as low as humanly possible when compressing it and also keep in mind that I had to bend the two inner protrusions inward to actually allow safe contact with the valve spring cap to prevent it from slipping. You may have to as well.
Once the spring has been compressed you will have a tiny little pain in the ass space to work in. BMW's valve spring retainers are two clamshells that fit into grooves cut into the stem of the valve. Their removal will require a pair of needle nose pliers and an awl. Use the awl to seperate the two clamshells and use the pliers to remove them. Once they're gone, the spring and compressor should pull off easily. DO NOT REMOVE THE SPRING FROM THE COMPRESSOR.
Here's what the two clamshells look like (sorry it's so blurry, but my cam sux):
In order to inspect the valve, first remove it from the valve guide. Then hold it up to the light and inspect the edge of the valve seat. It should have no nicks, scratches or carbon deposits on it. Exhaust valves will have carbon deposits pretty much everywhere but the actual seal itself, but keep an eye out for excessive deposits, and if you find them put the valve aside to be cleaned. Assuming everything so far is good, flip the cylinder head over and inspect the valve seat surface on the head. you should keep an eye out for the same sorts of imperfections. If everything so far is good, replace the valve and check to see that a) it rotates smoothly and easily in it's seat and b) there is no wobble or gaps while it rotates. If it passes these simple inspections, the valve is good. All valves with excess carbon deposits should be cleaned. If you don't know how, you shouldn't be doing it. Again, anything you feel out of your depth with in this procedure should be done by a professional.
Visually inspect the valves for bending and imperfections in the seat:
The valves shown here are the two exhaust valves from cylinder number 1, which made contact with their corresponding piston when the crank walked at idle due to the stupidity of the technician assembling the motor. The problem was traced to a failure to properly torque the crank main bearings properly. That's how I got my head at a good price. The valve in the center of the photo is from cylinder number 2, it is perfect and undamaged.
Reassembly is the opposite of disassembly. Keep in mind that the clamshell valvespring retainers are very very very very very very small. They need to be installed with the larger side of their wedge shape facing up. Be careful not to drop them as they are small enough to fit through the oil and coolant passages in the head as well as the head bolt holes and they're a fucking bitch to find if you drop them. The pliers come in very handy here. Our favored method was to put one clamshell on, rotate the valve in it's seat 180 degrees and then install the second clamshell. Then we lift on the valvespring compressor to hold the clamshells together while we uncompress the spring. Before intallation, make sure that both the valvespring cap and spring seat are properly installed. Failure to do so can severely damage the cylinder head and can also cause valve float. Obviously without the valvespring cap, the valvespring won't stay on. Duh.
This photo shows the reinstallation process. Note the grooves on the valvestem where the two clamshells fit on:
Don't forget that having the proper tools around is a massive help:
Oh and btw, the ports on the S50 are already fucking huge, I shit you not, the exhaust ports were big enough for my thumb to fit with lots of room to spare. The intake ports were bigger obviously, and they were gorgeous:
As always, be very careful with all this, and have happy wrenching!
Addicted to Speed Since 1997
Old 04-02-2006, 10:02 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
good looking.. cant wait for stage2
Old 04-02-2006, 11:21 PM   #3 (permalink)
Here are a few more photos to give you guys a chance to visualize how everything works.
Here's a side photo with the VANOS unit on so you can see how the helical gear works. The gear slides toward the cam carrier as the solenoid opens and allows high pressure oil into the VANOS unit and advances cam timing.
As you can see the other side of the cylinder is also covered by the VANOS unit, even though that side has no VANOS.
As you can see there's plenty of room to fit a double VANOS unit, and the Double Vanos M52 still uses the same cylinder head casting so it would make sense that with the cam carrier, camshafts and bearing caps from an M52Tu, you could mount double VANOS if you so chose. The only advantage would be infinite variability and improved gas mileage, but it would be more difficult to find aggressive enough camshafts to make a significant advantage in terms of horsepower. It's certainly true that I'm better off with S50 camshafts than with M52Tu camshafts and there's scarcely any gain in terms of fuel economy. It's likely that with forced induction and intelligent tuning, one could make a significant gain in boost response and ultimately make a gain in power as well.
Old 04-02-2006, 11:33 PM   #4 (permalink)
ex owner/admin
Furious's Avatar
nice nice. i have to pull my vanos out and clean it up a bit. its a bit noisy
Old 04-03-2006, 05:18 AM   #5 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
looking good mang...now get to the scrubbin, i see dirt!!! man, make it bling!!! :lol:
Edit: BTW, you have sexy skinny fingers...just like me.. lets be skinny finger lovers
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 04-03-2006, 03:09 PM   #6 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
hey trigg how much was an s50 head, just curious, I would like to try building a head, I mean I could get something cheap from say a civic, but if I got something like an S50 at least I could use it on my car once i'm done right?
Old 04-03-2006, 03:25 PM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I like where this is going... I like it stickied in the e36 forum too.... eventually it will fit nicely in the archives in the FAQ and DIY forum...
Good stuff man...
Les
1997 E36 M3 1990 E30 325i
Old 04-03-2006, 04:01 PM   #8 (permalink)
The cylinder head I bought was $500. It's very low mileage. The only work it needed was the two new valves, but given the nature of how it died, I figured it would be prudent to check the remaining valves. The VANOS unit is actually from the engine where my block came from. It's from a 99 323is, and it recently had the solenoid replaced. As I've said before, the M50 uses the same head casting, so I would imagine the heads would look very very similar. The ports may not have been bored out as much, however.
Next installment will probably be in a few weeks, when I have the time to take apart my M52B25 bottom end.
Old 04-03-2006, 04:41 PM   #9 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
stage 2, nawz,
stage 3, rebuild and repeat from stage 1
lol
ive seen this motor in person, its a beauty.....cant wait until it is inside of its host
Old 04-03-2006, 09:37 PM   #10 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
crankwalk ftw.
Old 04-04-2006, 02:05 AM   #11 (permalink)
iamjoe's Avatar
Location: The collected thoughts of a subconcious psyche trippin' on acid and THC. Chill as I take you on a tr
iamjoe is on a distinguished road
Send a message via ICQ to iamjoe Send a message via AIM to iamjoe Send a message via MSN to iamjoe Send a message via Yahoo to iamjoe
Those be my fingers man. Trigg's fingers are like the rest of his build. Fat, round, and kinda wobbly.
Trigg
Smoke up!
Joe
I'm allergic to stupidity. If exposed, I may begin to insult the cause repeatedly.
The liver is evil, it must be punished!
The Great and Ganjaful Pyrolah of the Secret Brotherhood of the Huzzah
iamjoe is offline   Reply With Quote
Old 04-04-2006, 04:34 AM   #12 (permalink)
vwk
vwk is an unknown quantity at this point
Just a question, are you going to put in a light flywheel? Because now you have a nice oppertunity to balance the crankshaft
Euro E36 M3 3.2 Rebuild Project
27 years
vwk is offline   Reply With Quote
Old 04-04-2006, 12:26 PM   #13 (permalink)
LYFE SUCK5
Ivan's Avatar
Car: 2008 Infiniti G35
Ivan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant future
Send a message via AIM to Ivan
Originally Posted by Torque
crankwalk ftw.
aint no dsm:lol:
Ivan is offline   Reply With Quote
Old 04-04-2006, 12:39 PM   #14 (permalink)
yes, I will be using a lightweight flywheel. I believe the UUC is 11lbs, that's plenty light for me.
Old 04-04-2006, 01:00 PM   #15 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Originally Posted by Ivan
aint no dsm:lol:
thats what happened to the engine he's now rebuilding tho. lol
The Frankenmotor Project: Step Two triggrhaapi FAQ's and DIY's 11 11-13-2006 11:58 PM
Step Tronic:Good,bad Why? Maximusmace 3-Series (E36) 28 05-29-2006 12:42 PM
Blacked Out Grills And Roundels BLACKBMW 3-Series (E36) 5 11-10-2004 12:35 PM
Mammoth e36 DIY El Presidente Audio and Electronics 0 06-24-2004 01:02 AM
