DIY E90 Rear differential oil change - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 05-12-2010, 08:53 PM   #1 (permalink)
hrc
Car: 2006 E90 330i
hrc is on a distinguished road
Send a message via AIM to hrc
Tools needed:
14mm Hex - 1/2" drive
1/2" drive Ratchet
Transfer Pump
Jack Stands/Ramps
Low profile floor jack
Drive the car around for a while to warm up the rear diff oil.
Then lift the car and make it level.
Remove the drain bolt and insert the transfer pump into the differential and remove the old oil - real nasty, dirty smelling stuff.
Wipe everything down and insert the intake side of th4 pump into the new bottles of oil and the release portion into the differential. Begin pumping until new oil starts overflowing from the drain hole. That is why the car needs to be level.
Wipe everything down again and screw the drain plug back on.
Done.
Thanks,
Danny
DIY E90 Rear differential oil change-dsc_2530.jpg   DIY E90 Rear differential oil change-dsc_2538.jpg   DIY E90 Rear differential oil change-dsc_2539.jpg   DIY E90 Rear differential oil change-dsc_2540.jpg   DIY E90 Rear differential oil change-dsc_2541.jpg
hrc is offline   Reply With Quote
Old 05-12-2010, 08:53 PM   #2 (permalink)
hrc
Car: 2006 E90 330i
Last pics.
Danny
DIY E90 Rear differential oil change-dsc_2542.jpg   DIY E90 Rear differential oil change-dsc_2543.jpg   DIY E90 Rear differential oil change-dsc_2548.jpg
Old 05-14-2010, 07:55 AM   #3 (permalink)
Car: Z3 2.0 2000 Cosmos Black
dudex is on a distinguished road
thanks bro i will try to do it at home, looks easy !!
dudex is offline   Reply With Quote
Differential Oil jas81172 3-Series (E21, E30) 0 12-27-2009 05:49 PM
Need Help -- 635 Differential Oil Change pbonsalb 1,6,7,8 - Series and Mini Cooper 0 11-06-2004 08:25 PM
Differential Gear Oil Change supark 3-Series (E36) 4 10-30-2004 02:54 AM
Debaffle DIY and performance change El Presidente 3-Series (E36) 64 09-04-2004 04:51 PM
DIY Oil Change CosmosBlack Bimmer Talk/Motorsports Talk 14 12-09-2003 03:01 PM
