BMW v57 SSS 32 TIS 12 - Advice needed on using these cables - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 08-29-2010, 01:30 PM   #1 (permalink)
tsam19 is on a distinguished road
Question BMW v57 SSS 32 TIS 12 - Advice needed on using these cables
Hello All
I am hoping to find out out if I can use the software BMW v57 SSS 32 TIS 12 for my BMW 1995 (Non OBDII) 2.5TD E36.
There is the 20 pin port under the bonnet, left handside.
I have 2 cables joined together (see pic) OBDII & BMW 20 pin.
I've been researching on how to use the mentioned diagnostic software with the cables on my car to clear the service lights & look at past faults etc recorded on the cars ECU, if there is any.
I believe from reading other threads it can be done.
Is there any other software I need to load to get the program to recognize the leads?
I know there is 'carsoft' with their own serial to 20 pin lead with their black box & various other cheap alternatives.
However I have chosen to use BMW v57 SSS 32 TIS 12 as it will prove useful if I ever change BMW type in the future.
Can anyone explain with instructions on how to use the software via the cables to connect successfully to my car & get the best from it?
I know its a relatively old car with limitations due to its non obdII capability.
So what drivers must I install for the cables I have, as I've plugged them in to the usb slot & there is a message saying unable to find drivers?
What other selections or procedures must I follow?
Thanks for reading & any help.
BMW v57 SSS 32 TIS 12 - Advice needed on using these cables-2.jpg   BMW v57 SSS 32 TIS 12 - Advice needed on using these cables-5.jpg   BMW v57 SSS 32 TIS 12 - Advice needed on using these cables-6.jpg   BMW v57 SSS 32 TIS 12 - Advice needed on using these cables-7.jpg   BMW v57 SSS 32 TIS 12 - Advice needed on using these cables-8.jpg
tsam19 is offline   Reply With Quote
2006 Bmw 325ci m sport - Some Advice needed. ZeeBBoy 3-Series (E46, E90) 0 06-24-2007 06:27 PM
2006 BMW Salvaged Advice Needed! mercenarie 3-Series (E46, E90) 2 08-21-2006 08:38 AM
BMW Warranty Period Almost Up - Advice Needed skyeblue818 3-Series (E46, E90) 6 05-18-2006 07:00 AM
