Battery change on 2005 525i - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 05-06-2008, 07:26 PM   #1 (permalink)
Car: 2001 M5 & 2005 525i
cindysuecj is on a distinguished road
Question Battery change on 2005 525i
Need help on how to change the battery on our '05 525i. I know you go thru trunk, but then what? Step by step would really help! Also does this also apply to our '01 M5?
cindysuecj is offline   Reply With Quote
Old 04-05-2009, 07:34 PM   #2 (permalink)
Car: 1986 BMW 325e
FearsOfWar is on a distinguished road
Battery replacement is standard on every vehicle on the planet.
1) Remove negative/ground (black) cable.
2) Remove positive (red) cable.
3) Pull out battery.
4) Put in new battery.
5) Replace positive cable.
6) Replace negative cable.
As a general warning though, if you have aftermarket CD players with anti-theft & a reset code, you'll have to put that code in before it will work. They are designed to shut down until you put the code in, every time it loses connection to the battery.
Also, if you have an onboard computer (like my 86 325e), you'll have to reset the units of measurement & time.
FearsOfWar is offline   Reply With Quote
How to do a Battery change in 2005 525i cindysuecj New Members Check In 3 08-07-2009 06:25 AM
The battery on my 2002 525i is missing... npnp 5-Series (E12,E28, E34, E39, E60) 4 11-17-2006 01:19 PM
'94 525i Battery Keeps Dying rita27 5-Series (E12,E28, E34, E39, E60) 4 08-28-2006 10:34 PM
Keyless Entry Battery Change Linds 3-Series (E36) 1 04-06-2005 09:48 PM
Disconnecting Battery On '93 525i DANSBMW 5-Series (E12,E28, E34, E39, E60) 2 03-03-2005 05:22 AM
