| I can't help with the woofers, but your radio manual should have a diagram for which speaker wires plug in where. All you have to do is go around to each speaker, and jot down which color is each speaker. Wire colors are the same as the battery, so a blue & red would be the positive for that set, and the blue & black will be the negative. Rinse, wash, repeat for each speaker. |
