Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > FAQ's and DIY's
Old 07-22-2008, 12:37 AM   #1 (permalink)
quality
Delmarco's Avatar
Car: 2001 330i
Photos: 20
Pictorial Guide to all the E36 BMW 3 Series (92-99) Keys
I thought this would be helpful for many of us buying used E36s and getting a variety of keys that each do different things.
Master Key (dealership only; $75) - Opens All Doors/Trunk/Glove Box and starts the car. If you have a 1995 to 1999 BMW your Keys will be chipped. Meaning that your car only starts when the chip is read by the ignition cylinder. It is a small dark grey magnetic object placed in the head of the key.
Valet Key (dealership only; $65) - Opens only the Driver's Door and Starts the Car. Does not do anything else. Intended for Valets, so they cannot open your trunk or glove box. This key is usually grey and is about equal size to the Master Key.
Wallet Key (dealership only; $50) - Opens All Doors/Trunk/Glove Box and starts the car. Intended to be kept in the driver's wallet/purse for emergency use only when the Master Key is unavailable(stolen or lost). This key is said by the dealership to be "disposible" for 1995 - 1999 cars with chipped keys. Meaning that the key will only start and drive your car limited times before the chip stops working. I have a chipped car and I've used my Wallet Key numerous times to start and drive car so I'm not sure how true that is. This key will be slim, small, black and plastic.
Master Keys w/ Alarm Control Flip Fob for Keyless Entry (aftermarket; $$$ varies) These Keys are sold as blanks and can be cut at very rare and specific specialist shops for about $20-$30. After cutting the key you can dissect either your Master Key or Valet Key and transfer the magnetic chip into the Alarm Fob body so the key fob can be used like a Master Key to start the car, etc... The Keyless Alarm control inside Fob body will either come with it's own aftermarket keyless entry alarm kit or can be program to work with the OEM Alarm or another aftermarket Alarm. Quality key fob like these are relatively rare to find online and once you get it, it may be difficult to find a local cutter that will cut it. And once you get it cut you will have to chip it, as well as connect the keyless Alarm functions. So it is a lot of work but the results can be very desirable.
BUYING KEYS: The OEM Keys can ONLY be bought at the dealership and they require only two things; Your Driver's License and the Registration Papers for the car. You must be the registered driver of the car to buy keys for the car so don't send your little sister or butler to get your keys. Also do not bring Titles or Dear John letters. You can also easily buy aftermarket blanks (as seen on ebay) and get them cut if you know a specialist that will cut it and if you don't need a chip in the key (1992 to 1994).
SECURITY NOTE: Do not keep your Valet Keys or Wallet Keys in the glove box or anywhere in the car. Thieves have been known to pry open glove boxes in search of Valet Keys. It is common knowledge that BMWs come with these keys so Theives take advantage of it.
Old 07-22-2008, 02:21 AM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: e36 2.8i; e46 zhp
Photos: 0
From my experience, what you labeled as the wallet key is also the valet key. What you label the valet is the non-lighted master key. I have both a lighted and a non-lighted master key. The lighted one is my backup. The other one does everything you describe the master key as being able to do. This is also consistent with what my instruction manual says
Turkey Fleet Bond Holder
Old 07-22-2008, 04:48 AM   #3 (permalink)
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
Thats actually innacurate. The keys you showed are EWSII keys. So that list is actually from 1994-1999. The non coded keys look different.
But thanks for playing!
Old 07-22-2008, 10:11 AM   #4 (permalink)
quality
Delmarco's Avatar
Car: 2001 330i
Photos: 20
Mmmmmmm. Does your Valet Key/Master Key have a groove line down the key body? Only the Master Keys will have that. A Valet Key as you see in my pictures do not have that groove line down the spine, which is why it does not open the glove box, trunk and other doors.
If you claim your Valet Key (one that looks exactly like in my picture, I mean exactly) does act like a master key, I would say that the previous owners did not buy it from the dealership and bought an aftermarket key and got it cut.
Like in the pictures below.
Also note that pre 1995 E36s had Master Keys that looked like this;
So that is what you probably have for your 1992 325i and think its the same as the valet key in my picture.
My bad, I didn't think anyone drove cars from pre-1994! LOL!
Stop whinning. I'm trying here. So if your car is a pre 1994 E36 (you have one of the last two left on the road) then your Keys look alittle different like the pictures in this post.
Old 07-22-2008, 11:07 AM   #5 (permalink)
drz
drz's Avatar
Photos: 0
Good call on the groove Del. My non-lighted master key does indeed have a groove along the length of the key.
Old 07-23-2008, 05:40 PM   #6 (permalink)
nukeduster's Avatar
Photos: 0
Nah man, sarcasm doesn't come across the internet as well it should. You and your willingness to help people to the best of your ability these days is refreshing to see. For someone who is always getting picked on for years now, you still try to be amazingly helpful. So good on ya man.
Btw, non vanos equipped cars ROCK. And there are still plenty out there.
-rich
vB code is On
OEM E36 Tailpipe Trim Upgrade Pictorial DIY Delmarco FAQ's and DIY's 8 07-21-2008 11:56 PM
Warped, Dented, Damaged E36 Nose Panel Quick Fix! (Pictorial DIY) Delmarco FAQ's and DIY's 2 07-20-2008 02:17 PM
DIY Pictorial Guide For E36 318i 318is 318ic 318ti M42/M44 Spark Plug Replacement Delmarco FAQ's and DIY's 10 07-08-2008 11:42 PM
Pictorial E36 Fuel Filter Maintainence DIY (Pictures) Delmarco FAQ's and DIY's 9 07-03-2008 07:06 PM
Halos/HIDs Pictorial Guide umnitza 3-Series (E36) 0 07-28-2004 03:13 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
