Originally posted by nreno88@Apr 20 2005, 12:08 PM dosnt solberg race for peugeot or am i thinking lobe anyway. i love the wrc and we need it to come to america. preferably the west coast. anyways i love the sti because i am subaru biased, while i still acknowledge that the evo8 is faster, just wait till they next gens come out and it should be a whole new ball game. im all for turbo and all wheel drive in the dirt. rock on with what ever you drive and when you drive it, drive it hard.
-nick [snapback]335421[/snapback] |
SOLBERG & PEUGOT???? DUDE put down the crack pipe!! LOL jus given ya crap, Marcus Gronholm drives for peugot and loeb drives for citroen. as for them being equals, (sti and evo) NOT A CHANCE the evo is no where near the STI off road. I used to drive rallies here in the us and ran with an STI. Yes we do have rallies here. it was run by SCCA but now Rally America is who is in charge of ours.
Evos are not faster. here are the specs:
EVO 8
LANCER
EVOLUTION RS LANCER
EVOLUTION VIII LANCER
EVOLUTION MR
Engine Type: Inline-4 Inline-4 Inline-4
Engine Block: Cast Iron Cast Iron Cast Iron
Cylinder Head: Aluminum Aluminum Aluminum
Displacement (cc): 1997 1997 1997
Horsepower @ rpm (SAE net): 276@6500 276@6500 276@6500
Torque (lb-ft @ rpm): 286@3500 286@3500 286@3500
Redline (rpm): 7000 7000 7000
Bore and Stroke (mm): 85.0 x 88.0 85.0 x 88.0 85.0 x 88.0
Compression Ratio: 8.8:1 8.8:1 8.8:1
Valvetrain: DOHC 16-Valve DOHC 16-Valve DOHC 16-Valve
Full-time AWD with Active Center Differential, front helical torque-sensing limited slip differential and rear 1.5 limited-slip differential:
Valve Cover: Magnesium Magnesium Magnesium
Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings, front: 320 mm dia. rotor,
4-piston calipers 320 mm dia. rotor,
4-piston calipers
Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings, rear: 300 mm dia. rotor,
2-piston calipers 300 mm dia. rotor,
2-piston calipers
Fuel Delivery: ECI-MULTI Electronic
Fuel Injection ECI-MULTI Electronic
Fuel Injection
Engine Oil Type: 100% Synthetic 100% Synthetic 100% Synthetic
Turbocharger Type: TD05HR-16G6-10.5T
(Twin Scroll Turbine) TD05HR-16G6-10.5T
specs on STI:
2.5-Liter DOHC aluminum-alloy 16-valve 4-cylinder horizontally opposed Subaru Boxer engine with Active Valve Control System (AVCS). Sodium-filled exhaust valves. Iridium spark plugs.
Horsepower
300 hp @ 6000 rpm
Torque (lb.-ft.)
300 lb.-ft. @ 4000 rpm
Fuel & Ignition System
Sequential multi-port fuel injection. Electronic Throttle Control (ETC). Engine management with integrated self-diagnostics and adaptive driving habits capability. Direct ignition.
Steering
Engine-speed-sensing quick-ratio variable power-assisted rack-and-pinion. Power-steering oil cooler.
Turning Circle, Curb-to-Curb
37.4 feet
Suspension
High-performance sport-tuned 4-wheel independent suspension. Front: Inverted strut-type with aluminum-alloy lower L-arm. Rear: Inverted strut-type with parallel link. Front and rear stabilizer bars.
Brakes
Brembo performance brake system. 4-wheel disc, ventilated front and rear. 4-channel, 4-sensor Super Sport ABS with Electronic Brake-force Distribution (EBD).
Manual Transmission (Standard)
Fully synchronized close-ratio 6-speed manual with clutch pedal-controlled starter interlock.
Symmetrical All-Wheel Drive (AWD)
Driver Controlled Center Differential (DCCD) AWD: Exclusive to the WRX STi. Features both manual and automatic modes, uses an electronically managed multi-plate transfer clutch in conjunction with a planetary gear-type center differential to control power distribution between the front and rear wheels. Normally, DCCD splits power 35% front and 65% rear. DCCD also features a helical-type limited-slip front differential and mechanical limited-slip rear differential.
so as you can see the STI is not only faster but as we (rally guys) know the STI will certainly beat an EVO. I like the EVO but if i have a choice i am going STI. Now the driver has a lot to do with the race though. good car bad driver = loss.
I am a bit biased though as i raced STIs in my rallies. Can't argue with the facts though.
also don't always go by what the magazines say. you gotta member what these cars are made for. autoX an EVO will have the advantage but not in rally. These cars are made based off the WRC version as that is a requirement for the cars driven in the WRC. the companies must make a certain amount of their cars production worthy in order to use them for rallies.
Chant
