Site question - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > Site > Bimmerwerkz.com Site Help
Bimmerwerkz.com Site Help A place for members to post site issues.
Old 09-12-2005, 01:30 PM   #1 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
Site question
What's the "user xyz is off the scale" or "user xyz is an unknown quantity" about? I noticed that under my avatar earlier today.
kestrel325is is offline   Reply With Quote
Old 09-12-2005, 02:16 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Good question... Noodles might know... probably just a fluke... doesnt seem to be there now...
Les
1997 E36 M3 1990 E30 325i
Old 09-12-2005, 05:18 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Smile
Reputation points. The 'scale' between 'report a post' and 'online/offline indicator' (bottom of your info on the left) allows you to give the user either positive or negative reputation ... every 'approved' you give them is 5 points added, and every 'dissaproved' is 5 points subtracted (I might be off on that, but the general idea is there).
If it says 'unknown quantity', it means the user is at 0 points and as such isn''t neither a positive or a negative. It can also say 'xyz is on a distinguished road' or 'xyz has a shameful past' or something along those lines, and those are self explanatory.
ps. I'll give you positive rep. on your post
edit: I forgot to mention that it leaves a little comment at the bottom of your post which says if i agreed or disagreed and any possible comments I may have left to go along with that.
And if you click your own 'scale' it will show you how many points you have. And when you first enter your USER CP (top left), at the bottom it lists all the threads and posts for which you recieved feedback/reputation points.
Good God, I type a lot.
edit: to answer your original question -- that little green/red/blue dot just is an easy way of knowing who the good or who the bad guys are.
Old 09-12-2005, 05:56 PM   #4 (permalink)
Great explanation. Thanks, Torque.
new to the site and got a question. FireDaemon21 3-Series (E21, E30) 5 10-10-2005 10:38 AM
Parts And Site Question... KBachman 3-Series (E21, E30) 0 04-20-2005 09:13 AM
info center in the gauge cluster question audiosolstice 1,6,7,8 - Series and Mini Cooper 3 04-30-2004 02:58 AM
