turbocharged/supercharged? - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > General Category > Bimmer Talk/Motorsports Talk
Bimmer Talk/Motorsports Talk Bringing the BMW community together, sharing NEWS, stories, and experiences.
Old 11-24-2003, 05:55 PM   #1 (permalink)
bimmerM5e39 is an unknown quantity at this point
ok is the only difference between the 2 that one is air intake and the other isnt. i mean i kinda think that not all too it obviously but wat elses is different. and supercharged is air intake right... so then wat is turbocharged. how do both work?
bimmerM5e39 is offline   Reply With Quote
Old 11-25-2003, 12:25 AM   #2 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
have you asked this question before?
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 11-25-2003, 07:23 AM   #3 (permalink)
the///man is an unknown quantity at this point
supercharger works off of the engine's pullies and turbocharger run off of the the exhaust
the///man is offline   Reply With Quote
Old 11-25-2003, 08:00 AM   #4 (permalink)
lwebb12's Avatar
Car: 2000 M5
they do the same thing. compress air going into the intake manifold.
Old 11-25-2003, 09:57 AM   #5 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
a supercharger unless its hooked up to a centrifugal clutch is basically consistant power thru all rpm ranges but you sacrifice a lil top end to it.. its also only used on high compression engines..
a turbo spools up power and then releases it at a certain rpm and holds it. turbo's are for top end (high speed) power. its also used on low compression engines..
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 11-26-2003, 12:34 AM   #6 (permalink)
sakuramboo is an unknown quantity at this point
if you have a six cylinder or bigger, youd want to go with a super charger, but if you have a four cylinder, then get a turbo. the four bangers produce more pressure in the exhaust than larger engines do. and the more pressure thats built up, the sooner that turbo will spool up, producing more hourse power sooner.
sakuramboo is offline   Reply With Quote
Old 11-26-2003, 10:29 AM   #7 (permalink)
CBA
CBA's Avatar
wtf gave you that idea?
the only reason most 4s are turbed is because they dont make enough compression to be super charged... hence low compression engines for turbo's not becuase of the back pressure in the exhuast..
-Founder
Old 11-26-2003, 11:13 AM   #8 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
hah, were do you get your information from, the bottom of a cracker jack box?? shitass. Turbo's are used on 4 cylinder engines to boast power and torque without having to increase the size of the engine, as well as still be very conservative on gas mileage. It has nothing do do with they work better on 4 cylinders than 12 cylinders, because there's a number of 10 and 12 cylinder engines that come equipt with bi-turbo's, or even v6 and v8's, Lotus Esprite V8 TT, Audi A4, A6, Mercedes CL55 V12 bi-turbo, buggati EB110 v12 quad turbo's, not to mention supra's I-6 Twin turbo, skyline I-6 Twin turbo. It can go on forever, size doesn't matter for shit. don't post shit that you can't back up with proof, especially in tech area's, cause it throws off people looking for real answers. fartsmeller
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 11-26-2003, 11:19 AM   #9 (permalink)
CBA
CBA's Avatar
this ownage brought to you by CBA and bimmerfan620..
thank you come again..
-Founder
Old 11-26-2003, 11:26 AM   #10 (permalink)
A... Fuckin men brother.
Old 11-27-2003, 04:47 PM   #11 (permalink)
w00t#29, lol, well thnax guys. so wat do u mean it uses the exaust for turbocharged? i thought it had like an air intake or somethin. is that just way off?
and no i havent posted this question b4.
Old 11-27-2003, 05:33 PM   #12 (permalink)
the amount of lag depends on the size of the turbo. a small to mid size turbo will kick in pretty early but trail off and create alot of heat in the top end, a larger turbo will have a larger boost threshold but will give more power, and run cooler. one example of the lag vs heat comprimise is the air cooled porsche 993 turbo
Old 11-28-2003, 04:24 PM   #13 (permalink)
ehlpitel is an unknown quantity at this point
turbo takes air in compresses it, and thats pretty much how it works w/out gett ing too complicated .....ive driven my friends turbo volvo 740, u could feel the turbo kick in w/the boost, and even though its a kinda weak car, u could still feel the boost, which made it feel pretty nice, but since its a not too serious of a turbo, i think u dont really feel the lag as mcuh, cause when theres not as much to be lagged?????? correct me if im wrong
ehlpitel is offline   Reply With Quote
Old 12-02-2003, 09:18 AM   #14 (permalink)
Colicious is an unknown quantity at this point
turbos are generally for higher RPM's, where superchargers are generally all around
Colicious is offline   Reply With Quote
Old 12-07-2003, 09:37 AM   #15 (permalink)
chuck540owner is an unknown quantity at this point
A turbo is like a motor. The motor (turbo) has a fan that pushes air into the air intake. The motor itself is driven by exhaust gasses that force it to spin. Since the turbo needs the gasses to turn, the engine must first be under load. (petal to the metal) that,s where the lag comes from. Hope I didn't over simplify this too much.
chuck540owner is offline   Reply With Quote
