Thrown a rod - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > General Category > Bimmer Talk/Motorsports Talk
Bimmer Talk/Motorsports Talk Bringing the BMW community together, sharing NEWS, stories, and experiences.
Old 01-15-2004, 06:41 PM   #1 (permalink)
AUS_M3.2L is an unknown quantity at this point
Hey I havent thrown a rod on my car, but in school we are doing a mock trial and the case consists of this guy blowing his engine and then sueing the person he bought it from. What i need to know is, What is the most common reason an engine blows? Overheating, not changing the oil. Are the pistons checked during a tune up? Thanks, if you can give any help, it is truly appreciated.
AUS_M3.2L is offline   Reply With Quote
Old 01-15-2004, 07:41 PM   #2 (permalink)
dubumb's Avatar
dubumb is an unknown quantity at this point
Send a message via AIM to dubumb
my guess would be overheating if the car is driven under normal conditions (not racing blah blah) The spark plugs are supposed to be check/replaced during a tuneup i believe... And as for the oil not being changed, that would be done with a tune up
<center>
<img src='http://www.ownster.com/forums/uploads/post-10-1076044411.jpg' border='0' alt='user posted image' />
<a href='http://www.cardomain.com/id/dubumbz' target='_blank'>my car @ cardomain....</a>
<a href='http://www.ownster.com/' target='_blank'><img src='http://www.bmw-forums.com/forum/uploads/post-4-1075256000.gif' border='0' alt='user posted image' /></a>
&lt;/center&gt;
dubumb is offline   Reply With Quote
Old 01-15-2004, 07:57 PM   #3 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
the case would hold no water in court. when you throw a rod its usually a result of careless over reving.
other ways an engine could blow.
-lack of coolant.
-lack of oil and or oill changes.
-use of unreccomended oil grade at cold climate temps. this results in a thicker oil hence increasing the friction on the lube points of the oil.
-cracked head allowing oil to mix with collant would wipe out the bottom end.
the list is pretty much endless those are just common causes.
the pistons are not checked during a tune up to check them it would require a tear down of the engine both top and bottom end.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-16-2004, 02:30 AM   #4 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
9 out of 10 times a thrown rod is because of over revving. The other times I've seen a rod go is under extream engine load, bad build quality of the motor(incorrect torquing of parts) or a defect in the rod itself.
My M50 Powered E30 Page
Rod Bearing recall Lex M-Series (M1, M3, M5, M6) 9 10-14-2005 11:35 PM
