Im lookin for a good oil filter for my bmw. Im thinking about getting a Spin-Flow Filter, but I need some feedback on it. I know that NAPA makes the best so I’m not worried about its quality, but I would like to hear other peoples opinion on it
Oh, there is also some instant win contests running. I found everything at the links below. Check them out, the sites are pretty cool!
http://www.napafilters.com/nselect/ http://winningspinsweepstakes.com/
sum info on the filter...
Spin-Flow is an new oil filter by NASCAR Select that has special flowing fins that
channel oil through the filter to eliminate turbulence and direct large particles down and away from the filter media to improve oil flow and filtration efficiency.
In traditional oil filters, oil rushes directly into the filter creating in-filter turbulence that restricts flow through a significant portion of the filter media.
That means the oil has to work harder to filter through approximately 60% of the media. That's very inefficient. By comparison, the NASCAR Select with Spin-Flow performs at maximum capacity and efficiency, which leads to a better-performing engine. In the NASCAR Select with Spin-Flow, angled fins channel the flow of oil as it enters the filter. Oil circulates through the entire filter directing large particles down and away from the filter media resulting in the efficient flow of oil and a minimum of turbulence.
