Premium Gas - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > General Category > Bimmer Talk/Motorsports Talk
Bimmer Talk/Motorsports Talk Bringing the BMW community together, sharing NEWS, stories, and experiences.
Old 07-25-2003, 12:29 PM   #1 (permalink)
donutchow is an unknown quantity at this point
why do bmw's require premium gas? and how does the engine know the difference in octane, if you put in regular 87 does it not run as well, or could it actually cause harm to the engine?
Founder of the 3 pedal club, the first actual club on BMW-Forums.
donutchow is offline   Reply With Quote
Old 07-25-2003, 12:42 PM   #2 (permalink)
bmw and many other perfromance built engines require premium gas becuase of their high compression. but u can run 87 octane in most bmw engines becuase they have knock/ping sensors that will automatically reduce the engines capabilities so the engine will run smooth and so the lower octane gas wont hurt the engine, but it still isnt a good idea becuase it will feel less powerful and it isnt the way the engine is meant to run
Old 07-25-2003, 12:51 PM   #3 (permalink)
DesmoBob's Avatar
http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
knock = pre-detonation of the fuel before the spark can ignite it
Old 07-25-2003, 01:48 PM   #4 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
I don't really mind paying for premium. There is a 76 station near me that has this high octane fuel at 115 its like $3.25 a gallon. I was thinking about filling up with that, what do you guys think?
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 07-25-2003, 01:54 PM   #5 (permalink)
DesmoBob's Avatar
egad don't do it. unless you have radically advanced your ignition timing or are revving to 10,000 rpm.
there's one unocal station here too that sells ridiculously high octane stuff. i think only the full-on dragstrip guys use it.
Old 07-25-2003, 01:55 PM   #6 (permalink)
2.link's Avatar
Originally posted by DesmoBob+Jul 25 2003, 11:34 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (DesmoBob @ Jul 25 2003, 11:34 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Asio@Jul 25 2003, 10:28 AM
egad don't do it. unless you have radically advanced your ignition timing or are revving to 10,000 rpm. [/b][/quote]
? used
Old 07-25-2003, 02:01 PM   #7 (permalink)
DesmoBob's Avatar
i.e., you won't notice any benefit. high octane = retards detonation. 92 should be quite sufficient for street cars. when you advance your ignition (like a racing motor), you are predisposed to predetonation, thus needing higher octane (100+). also, if you are running really high compression (resulting in higher revs), predetonation can be even more catastrophic.
Old 07-25-2003, 02:05 PM   #8 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
I.E - Engine fall down go Boom. ghead
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 07-25-2003, 03:24 PM   #9 (permalink)
2.link's Avatar
Originally posted by GreenDragon+Jul 25 2003, 11:45 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (GreenDragon @ Jul 25 2003, 11:45 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-DesmoBob@Jul 25 2003, 05:41 PM
I.E - Engine fall down go Boom. ghead [/b][/quote]
ah ty for explaining it in english to me :P I did understand all the techinbabble that he said too...
Old 07-25-2003, 04:26 PM   #10 (permalink)
fatty is an unknown quantity at this point
in mine i only use shell optimax fuel.... (higher octain)
fatty is offline   Reply With Quote
Old 07-25-2003, 11:56 PM   #11 (permalink)
m42technic's Avatar
m42technic is an unknown quantity at this point
Send a message via AIM to m42technic Send a message via MSN to m42technic Send a message via Yahoo to m42technic
Basically, buying gas with an octane rating higher than your car requires = flushing your money down the toilet.
<span style='font-size:8pt;line-height:100%'>James
'91 318is</span>
m42technic is offline   Reply With Quote
Old 07-26-2003, 02:49 PM   #12 (permalink)
whys that.....
mine seems to be running a lot faster on the higher octain....
Old 07-26-2003, 03:14 PM   #13 (permalink)
Car: 325iX, 735i, X5 4.4i
Spetsnaz Op is an unknown quantity at this point
Send a message via AIM to Spetsnaz Op
i'd run 89, then again i'm cheap
Certified Alaska BMW Snow Warrior
Spetsnaz Op is offline   Reply With Quote
Old 07-26-2003, 06:46 PM   #14 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
i use 91-92octane and one time, right about to leave Ohio, i had half of a tank of normal 91octane fuel, i filled up the rest with 100 octane at a sunoco station. drove from Ohio to MD with ONLY half a tank! usually its a full tank of gas from Ohio to MD (about 380 miles) So 380miles with half a tank is incredible. The only explaination I have is the higher octane fuel i pumped in.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 07-26-2003, 06:51 PM   #15 (permalink)
Damn. It probably mixed to give you a high 90's octane fuel up in there. Sweet.
Erratic Gas Guage misterervin 3-Series (E21, E30) 5 09-22-2005 08:20 AM
Premium Gas - The Definite Article rsn48 3-Series (E46, E90) 12 03-27-2005 06:01 PM
Premium vs Regular Gas??? donutchow Bimmer Talk/Motorsports Talk 22 10-06-2004 01:09 PM
