ABS sensor light fault.. - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > General Category > Bimmer Talk/Motorsports Talk
Bimmer Talk/Motorsports Talk Bringing the BMW community together, sharing NEWS, stories, and experiences.
Old 04-14-2003, 10:39 AM   #1 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Ok, life goes on..
Today I jacked up my ride using my certified BMW car jack on each corner of my bim to take my wheels off one at a time to wax them and also to check out the rotors and pads to make sure everything's ..But I think it caused a fault in one of my sensors 'cause when I was finished I started her up and the ABS sensor light came on and stayed on..
I did a little research and came across this post on another forum..
I recently has the same problem. It is the ABS sensor probalbly on one
of the front wheels. Eventually what will happen is that the light will
stay on every time you will turn ignition on. ABS stops working in that
case. While reading this digest several months ago, someone suggested to
clean the sensor, however, it is ridiculous and stupid suggestion. IT
WILL NOT HELP, whoever gave that suggestion had no idea of what he/she
was talking about. The only way is to replace the sensor, the sensor for
the front wheel cost $95, or at least that is how much I paid for it on
You can test the sensor by
disconecting it from connector and attaching ohmmeter to it, if the
resistance is infinite, that means that the sensor is bad and needs
replacement. The proccess of replacement takes about 15 minutes. You can
find more material on replacing the sensor from Chiltons Book.
Defective front wheel sensors is a very common problem in BMWs.
I'm calling the dealer on Monday and will post up!!
Thanks!!
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 04-17-2003, 10:12 AM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Taking the tires off f'ed up your ABS sensor? That's messed up. Did you check to make sure it didn't just losen up accidentaly when you pulled the tire? I was considering rotateing my tires this week end myself, but now you got me double thinking that (plus I can't balance them so I may just take it in anyway).
95$ is quite a bit of scratch for the sensor, but the fact that ABS won't work if the light is on makes it kinda worth it. Shit Ski, I feel for ya. Let us know what it turns out to be.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 04-18-2003, 04:10 AM   #3 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
why would you want ABS? I cant stand it, i pulled the fuse on mine cause i like to have maximum control over the car. Sometimes it benefits to lock the wheels, especially when you have very good breaks and know the front and rear threshholds.
Fox is offline   Reply With Quote
Old 04-18-2003, 07:27 AM   #4 (permalink)
wtf that isnt very good reasoning. how often do u lock up your brakes anyway? and what kind of brakes do u have? maybe on a bicycle it gives more control to lock the rear wheel during sharp turns, but that doesnt apply to cars. your still putting equal pressure on the front brakes and could easily create understeer. also in wet roads ABS could save ur ass in so many ways it makes no sense to cut off your ABS. ABS doesnt interfere like ASC or DSC, it only activates in emergency unexpected situations, and acts to give u more control.
if ur a fan of braking oversteer then use the handbrake.
Old 04-18-2003, 10:35 AM   #5 (permalink)
Ski
Ski's Avatar
Light went off the next day so I'm no longer concerned about this..
GD, Is that you in your sig??
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Old 04-18-2003, 11:10 AM   #6 (permalink)
e36_m3_Turbo's Avatar
i was wonderin the same.. :lol:
No longer red.
Old 04-18-2003, 08:38 PM   #7 (permalink)
Yep, that's me. Plastered after a friends wedding.
Good to hear the light went off. Probably some dirt or 'scare tactic' put in place by BMW :lol:
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
ABS System failure!!Advise needed please. BMWstealth 3-Series (E46, E90) 9 10-12-2005 08:20 PM
Obd1 Fault Codes, Help! toast_mcmann 3-Series (E36) 10 08-01-2005 10:08 PM
1998 M3 Fault Codes beemernubee 3-Series (E36) 1 03-27-2005 01:26 PM
