325i engine underrated???? - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > General Category > Bimmer Talk/Motorsports Talk
Bimmer Talk/Motorsports Talk Bringing the BMW community together, sharing NEWS, stories, and experiences.
Old 07-31-2003, 09:50 AM   #1 (permalink)
donutchow is an unknown quantity at this point
i was checking out the acura tsx board and this is what i saw, someone had a dyno graph:
__________________________________________________ __-
Well the peak numbers are all essentially the same.
-----2.5L six-----------2.4L four
HP---170.1------------169.9
TQ---156.3@3500---152.4@2800
Both HP numbers come essentially at redline.
If you do some calculation using a driveline loss of about 14% for both cars (pretty standard), you get at the flywheel:
-----2.5L six---2.4L four
HP---197.8----197.6
TQ---181.7----177.2
Which tells us that BMW's HP number was underrated (which I expected), and that the TSXs torque number was underrated (which we knew from the TOV review). So, the TSX has just under FOUR less lb-ft of torque, but it comes on at 700 RPM EARLIER (i.e. more low-end torque). It looks like the TSX torque curve is flatter, but that's due to the differing scales on these two charts. They're both about the same degree of "flatness".
Founder of the 3 pedal club, the first actual club on BMW-Forums.
donutchow is offline   Reply With Quote
Old 07-31-2003, 12:03 PM   #2 (permalink)
do you have the actual charts? i'm suprised the tsx would have a flatter tq curve than a 325
Old 07-31-2003, 12:55 PM   #3 (permalink)
L337E46's Avatar
L337E46 will become famous soon enoughL337E46 will become famous soon enough
Isn't the TSX FWD?
General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
L337E46 is offline   Reply With Quote
Old 08-03-2003, 02:14 PM   #4 (permalink)
sport3
Guest
Posts: n/a
in my limited knowledge of dyno testing, mostly from reading AA's website, standard drivetrain loss for bmw's at least, is 16-17%. Ive found a dyno for a E36 325, with 189hp stock. 189hp * .84 = 158.76 RWHP , which is remarkably close to what AA got for "base" run. The new E46 325 has what? 184hp? Loosing only 14hp from flywheel to rear wheels is insane. Even if it was underrated, which it is not, why would BMW use such a low number? Im not saying it cant happen, i just dont believe your sources are accurate. There is no way that 2.4cyl achieves its torque that low, lower then a I6. Like MrM3 said, i would have to see the charts before i made any final conclusions. Just from reading the topics here, ive gone from knowing hardly anything, to finding out ALOT, thanks guys!
o, by the way, here was the link from AA: http://www.aatuning.com/dyno/94_325i_vs_94...upercharged.asp
Old 08-03-2003, 02:41 PM   #5 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
from numerous sources, i have read that BMW do underrate their engines and that BMW is excellent at transfering power to the wheels with minimal horsepower loss
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
325i Engine Mods M3wannabe2004 3-Series (E36) 8 07-20-2005 09:10 AM
320i V 318i WarNox 3-Series (E36) 23 01-25-2005 02:48 PM
Wanted 1992 - 1998 325i Engine & Electronics conzi_dv8 3-Series (E36) 3 01-06-2005 08:43 PM
Engine Swap Possibilities To 325i Tee Koo 3-Series (E21, E30) 3 12-10-2004 08:28 AM
will a 325i engine fit in my 318i ? laxinmiah22 3-Series (E36) 11 08-08-2004 02:17 PM
