» Sponsors
» Sponsors
Old 07-01-2004, 07:41 PM   #1 (permalink)
Defector
El Presidente's Avatar
Photos: 0
So I did some work on the car today which took me a lot longer than expected. I moved my LED to its permanent home, but my WD lied and told me some wires were switched 12v when they werent. Got that sorted out though I'll post a DIY later.
So after that I decide to hook up the XM and actually subsribe, since my free one ran out last friday and I didn't install the power wires when I installed the box. I had hooked up twice ghetto-style to make sure it work by pluging bar wire into the pos and neg bat terms. Worked fine. Now I go actually install it properly and it won't work. The display goes back and forth between no signal, loading, and ch 0 or 1. There is no sound with the ch 0 or 1 though, but the radio ID lights up fine.
Help?
Old 07-01-2004, 07:45 PM   #2 (permalink)
jllphan's Avatar
Photos: 0
so it powers up but no audio?
The sat radio boxes are finicky, and the antennas are even more so. You may just need to unplug the din plug, wait, and try it again.
Old 07-01-2004, 07:46 PM   #3 (permalink)
Defector
Photos: 0
I was hoping it was that. Any ideas if it's not?
Also, should I fuse it? The install directions mention nothing of it, but I don't like the idea of an unfused-permanently installed device.
Old 07-01-2004, 07:52 PM   #4 (permalink)
Car: 2008 128i
Photos: 0
Its not gonna hurt to fuse it... better safe than sorry.
2008 128i Jetblack
Old 07-01-2004, 07:53 PM   #5 (permalink)
jllphan's Avatar
Photos: 0
The display is pretty informative as to what is wrong. No signal general means that your antenna is not working properly. If you do as stated above, and you get the "no signal" message again, do the same aforementioned procedure with the antenna. The antenna lead is VERY fragile and you don't want it to get creased or you are f#$cked and have to go get another.
I would deffinately fuse it, but I have yet to see an Alpine XM box without an inline fuse on the constant lead (yellow, I believe). IF there isn't one for some reason, just trow one on dere!
Old 07-01-2004, 07:54 PM   #6 (permalink)
Defector
Photos: 0
Damn, I bet I creased the wire moving the box into position.
Old 07-01-2004, 10:30 PM   #7 (permalink)
Defector
Photos: 0
No probs after all. I assumed the terrestial repeaters would let me pick up a signal in the garage. Guess not. Backed out and it works fine.
That reminds me...its time to subscribe!
Old 07-02-2004, 05:45 PM   #8 (permalink)
jllphan's Avatar
Photos: 0
HA HA HA HA HA! I thought surely you were outside! No worries, the first time I installed mine in my last car--> hooked it all up, no signal. Called Sirius, they couldn't figure it out. Took it all a part, reinstalled it...no signal. 2.5 hours of this lead me to the conclusion that I might have better luck if I backed out of the install bay!
vB code is On
Automatic Climate Control prob cub_fever 3-Series (E46, E90) 2 09-07-2005 02:14 PM
Have Searched But, Sunroof Prob Plz Help Roo 3-Series (E36) 3 01-18-2005 11:49 PM
1994 540i Atom. Shifter Knob Prob feranndoc 5-Series (E12,E28, E34, E39, E60) 0 01-07-2005 11:00 AM
Fuel Pump Prob...any Suggestions mosyslack 3-Series (E21, E30) 5 11-23-2004 07:26 PM
IC/Stereo wiring prob FroznToes 3-Series (E21, E30) 3 05-02-2004 12:20 PM
