wiring XM tuner - BMW Forum - BimmerWerkz.com
Old 06-06-2004, 02:02 PM   #1 (permalink)
Defector
El Presidente's Avatar
I'll need to wire the XM soon, and I was wondering if anyone knows if I can use the factory CD changer power leads. It would be much easier than wiring to the battery.
Old 06-06-2004, 05:38 PM   #2 (permalink)
Car: 2008 128i
check the power off them with a volt meter if you got enough go for it.
2008 128i Jetblack
Old 06-07-2004, 05:57 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
Hey prez, why would it be easier to use your changer's power over the bat.? They are both in the trunk. Granted the changer's power is regulated and the bat. is not, but the XM box is fused and you shouldn't run into any problems there. At any rate, I'm sure you "steel" power from the changer, however, you may need to add a relay to keep both at +12volt minimum.
Old 06-07-2004, 10:38 PM   #4 (permalink)
Defector
Well the changer isnt running off of it, I sold that here long ago. I just wanted to know if I could use that to power it since the wires are already run and not being used. I'll go play with the VM tomorrow and see if it will work.
Old 06-08-2004, 09:28 AM   #5 (permalink)
Car: 2008 128i
Should be fine to run the XM off if. I imagine it would draw less than the changer.
2008 128i Jetblack
Old 06-08-2004, 11:28 AM   #6 (permalink)
WOT in Reverse
jllphan's Avatar
Gotcha. That should work out great! Most of the XM boxes draw less than 3 Amps, so I'm sure this would work.
Old 06-08-2004, 11:35 AM   #7 (permalink)
Defector
good to know. Now if only the factory CD plug would work with the AiNet...
I dread running a new cable. Its too hot outside.
Old 06-08-2004, 01:14 PM   #8 (permalink)
WOT in Reverse
jllphan's Avatar
AiNet is cool. I never noticed until the other day you had amber illumination. Or did you just trick us and hit the function button to make it change temporarily?
Old 06-08-2004, 03:43 PM   #9 (permalink)
Defector
nope, the 7894 has green/amber illumination at all times. one of the main reasons I bought it.
wiring angel eyes Nitrosport2000 5-Series (E12,E28, E34, E39, E60) 10 11-09-2005 06:39 AM
Engine wiring harness zinger 3-Series (E36) 0 09-20-2005 12:58 PM
Front Fog Lights Installation & Wiring Paraklas 3-Series (E21, E30) 0 11-04-2004 05:13 PM
Power Rear Vent Window Wiring jswanson3 3-Series (E36) 0 10-28-2004 03:51 PM
E36 -> E46 Wiring amp / sub / HU EcianIce Audio and Electronics 7 09-24-2004 10:45 AM
