Wiring diagram for Stock e36 amp?? - BMW Forum - BimmerWerkz.com
Old 10-25-2003, 08:54 PM   #1 (permalink)
Turbotec is an unknown quantity at this point
hi guys, I am installing an alternative amp for a single sub in the trunk, and I want to keep the stock system in for right now with the stock deck. anyways my question is, I need to tap into the rear speaker wires. I see the amp, but cant make sense of which one is the rear set of wires and which is the in and out of the amp. I am guessing the farthest one back with the big White/red wire is the in connector. so what would be a good set of wires to tap into for a set of left and right incoming amp leads. also one more thing. I need a wire that turns on when the ACC. is on. so that way my amp isnt on all the time. basically I need a remote lead. I want one in the trunk so I dont have to run the wire all the way up to the front. help here. what is that wire too! let me know as soon as possible, I need this thing installed by tomorrow
thank
Lance
Turbotec is offline   Reply With Quote
Old 10-25-2003, 09:06 PM   #2 (permalink)
another question. when installing my amp, what do you think, should I take the wire going into the amp for the inputs to my new amp, or grab it on the way out of the stock amp, for my new amp input. basically what I am asking is should I be running it through 2 amps?
Old 10-25-2003, 09:07 PM   #3 (permalink)
one more thing.....I cannot get those dumb connectors off the amp. how do I dissconnect the amp connector #2 the one with the most wires.
Old 01-24-2004, 03:02 AM   #4 (permalink)
louiepy is an unknown quantity at this point
you can access the rear speker wires where they connect to the speakers. If you go into your trunk and look up where the speakers are you should be able to see the wires. You can use them for a signal to the amp.
louiepy is offline   Reply With Quote
Old 01-24-2004, 10:54 AM   #5 (permalink)
eloff19's Avatar
eloff19 is an unknown quantity at this point
Send a message via AIM to eloff19
i recently installed a sub in my car as well...
the speaker wires your looking for are blue and yellow, there are little stripes going around them to help you discern from positive (+) and negative (-)
hope that helps...
right (+)=blue/violet
right (-)=blue/green
left (+)=yellow/violet
left (-)=yellow/brown
hope this helps!
eloff19 is offline   Reply With Quote
wiring diagram Kowalski 3-Series (E21, E30) 2 10-24-2005 01:29 AM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
Crank Angle Sensor wiring diagram Le_max 3-Series (E21, E30) 1 07-06-2004 05:25 PM
Another question - wiring diagram Garz 3-Series (E36) 2 05-20-2004 02:39 PM
WIRING DIAGRAM NEEDED PHYUKEWE Bimmer Talk/Motorsports Talk 0 04-15-2004 02:59 AM
