| Just Lifted this from Autotoys.com someplace. I'd imagine wireing is the same. Hope it helps..
The Anti-theft connector 1993 E36:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
x x
x 1 2 3 4 5 6 x
x x
x 12 11 10 9 8 7 x
x x
Pin # Function
1 Domelights ****
2 Trunk sensor (negative type)
3 Central Locking System, Unlock (+12V triggers)
4 Central Locking System, Lock (+12V triggers)
5 Hazard Lights (negative trigger)
6 Siren Connection
7 +12V Constant (Battery)
8 +12V Switched Through Ignition
9 Ground
10 Passenger Door Sensor (negative type)***
11 Driver's Door Sensor (negative type)***
12 Empty on my '93 318is
Hood switch (if available) is violet/green/yellow.****
__________________ 2008 128i Jetblack |
