Window Rolls Down When Door Opens. - BMW Forum - BimmerWerkz.com
Old 11-06-2004, 04:26 PM   #1 (permalink)
Ronny is an unknown quantity at this point
My e36 94 2dr 325 came like this when I bought it.
It's even different for each door.
For the drivers door:
Window rolls down when I open the door.
Window rolls back up if I lock the doors with the remote.
For the passenger:
Window rolls down when the door opens.
Window rolls up when the door closes.
What could be causing this and who do you think I should take this to to fix it. It gets quite annoying. I've gotten to the point where I dread opening the door.
Ronny is offline   Reply With Quote
Old 11-06-2004, 06:26 PM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
Do you have an aftermarket alarm? If so, it's probably that.
If not, my guess would be a relay, but I'm really not sure.
Old 11-07-2004, 01:20 AM   #3 (permalink)
Originally posted by jllphan@Nov 6 2004, 06:26 PM
Do you have an aftermarket alarm?* If so, it's probably that.
[snapback]225891[/snapback]
Yes I do. The previous owner had an aftermarket alarm system, which I replaced with a viper system.
Is there a way to turn that off? I don't think it's a feature of the security system, but a bmw mechanic said it might be something programmed into the module.
Window Trouble Sporty540 5-Series (E12,E28, E34, E39, E60) 4 01-10-2005 11:49 PM
Power Window Problem 123NotIt 3-Series (E36) 4 12-02-2004 02:02 PM
Power Window And Door Lock Problem...96 750il moabxj01 1,6,7,8 - Series and Mini Cooper 1 11-16-2004 03:30 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
Power window fun! kestrel325is 3-Series (E36) 7 07-17-2004 09:56 PM
