whistling noise though speakers - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 03-05-2006, 01:38 PM Thread Starter
glyndawn is on a distinguished road
Question whistling noise though speakers
hi
i have a jvc head unit in my 325 ise and a jbl 1100 watt amp in the boot but i carnt get rid of a whisting noise though the speakers i have a pair of fusion 6x9 in the back these r where the noise comes from i have changed these thinking it was the speakers but no joy any help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!used: used: used: used:
glyndawn is offline
post #2 of 5 (permalink) Old 03-05-2006, 02:42 PM
da_administrator
da_bull's Avatar
da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute da_bull has a reputation beyond repute
Originally Posted by glyndawn
hi
to the forums
do you have an amp running your 6x9"s? If so, its a possibility its in there. Motor noise comes from a multiple array of areas. It could be the radio, amps, wire routing, alternator, quality of cables, and/or a bunch of other things. It takes a lot of troubleshooting to get rid of it. A lot of times its in the grounding of amplifiers. I would start with that first. If you have an amp running the mids, turn the gain down a bit and see if the noise is more quiet.
da_bull is offline
post #3 of 5 (permalink) Old 03-26-2006, 08:11 AM
Saggis is an unknown quantity at this point
Had the same problem with mine...i had a couple of audiobahn 12cm's
The whining noise is never becouse of the speakers(if you havent done some seriously bad wiring, which I dont think).
Most good amps have a filter that takes away the engine noise and all fluctuations in the hull. Sometimes this filter can be faulty...so if your amp is supposed to have it i would try to get it changed for a new one at the shop you bought it.
Or if you want to make it simple you just go down to the nearest car-audio shop and get yourself an RCA filter which should remove the whistling sound.
Remember that these fitler usually are only for a pair of RCA cables so if you got 4 RCA inputs you neede two filters..
Good luck!
Black E39 530i 2001 with full black leather interior and antracit roof.
Saggis is offline
post #4 of 5 (permalink) Old 04-23-2006, 01:03 AM
Wonderboy's Avatar
Wonderboy is on a distinguished road
you need a filter and resister on the constent wire from the back of the deck. It should be the yellow wire on the head units wiring harness. good luck.
Wonderboy is offline
post #5 of 5 (permalink) Old 04-23-2006, 11:38 PM
RexKing86's Avatar
Quoted: 1 Post(s)
RexKing86 is an unknown quantity at this point
Send a message via AIM to RexKing86
check your ground wire and that your power wire isnt near speaker lines
RexKing86 is offline
  BMW Forum - BimmerWerkz.com > General Category > Audio and Electronics
whining noise from speakers kc740i Audio and Electronics 8 04-04-2006 05:34 PM
Whistling Noise... funtoos 3-Series (E36) 11 07-11-2005 08:35 AM
Loud Whistling Noise In Engine morristhecoolcat 3-Series (E36) 0 05-11-2005 02:54 PM
need helps replacing speakers noamkrief Audio and Electronics 1 09-12-2004 09:20 PM
Whistling noise mlseaver 3-Series (E46, E90) 3 04-12-2004 10:44 PM
