Where is my Amp? - BMW Forum - BimmerWerkz.com
Old 03-14-2004, 08:25 PM   #1 (permalink)
del23 is an unknown quantity at this point
Thumbs up
If I have an amp, where is it located? If I install a new HU is the amp bypassed with the aftermarket wiring harness? How powerful is the amp? Anything else I should know about installing the aftermarket HU. I should only need the wiring harness correct? Everything else should fit without a kit correct? What size is the hex screw btw....thakns for your help
del23 is offline   Reply With Quote
Old 03-14-2004, 09:16 PM   #2 (permalink)
Car: 2008 128i
I think a 5 or 6 is the hex size.
The wireing harness does not bypass the amp.
The amp is most likely in the trunk on the drivers side behind the sidewall.
I'm not sure what if any extra work the HK system need for a change out.
To bypass the amp you can either rewire everything at the amp using all the stock wiring in the trunk. But the better method would run new wires to all the speakers and possibly replace some as well or get some passive crossovers depending on how the HK amp is configured....
What did i miss?
2008 128i Jetblack
Old 03-15-2004, 12:26 PM   #3 (permalink)
Defector
El Presidente's Avatar
you got it all
Old 03-15-2004, 06:10 PM   #4 (permalink)
Car: 2008 128i
woohoo
2008 128i Jetblack
Old 03-22-2004, 06:20 PM   #5 (permalink)
neil12345 is an unknown quantity at this point
on a convertable the amp is behind the rear seats on the drivers side maybe in urs it will be around by drivers rear quarter panel. the converter plug will be rca type plugs (low input) and you will need a stereo with front and rear audio outputs there will be a remote wire to activate the amps built into the converter. this is so you still use the original amp which I think is alpine.try www.autoleads.co.uk the amp on a cabriolet is about 12in square so you can miss it if its the same as urs!
neil12345 is offline   Reply With Quote
Old 03-22-2004, 06:23 PM   #6 (permalink)
by the way upgrade the speakers, put some expensive ones in must be quality and the amps will be quality they sound very loud and clear
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
For sale 12" Apline Speaker and 1400 Watt Amp scottm3 Audio/Miscellaneous Auto Parts 4 03-31-2006 09:53 PM
AMP Power cable! 316i e36 94 Butterfingers Audio and Electronics 1 10-09-2005 08:44 PM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
