Where to mount the CD Changer on 318ti ?? - BMW Forum - BimmerWerkz.com
Old 11-24-2003, 07:04 AM   #1 (permalink)
cpuken is an unknown quantity at this point
I'm in the process of replacing the 10 disk changer that came with my recently purchased 95 318ti and all of a sudden I realize that the previous location (left side of the trunk) might not be the Ideal location. Hopefully one doesn't need to get to the tool set often but I can see where my current location is a little bit of a pain.
Where have you guys mounted your cd changers in your hatchback BMWs.
thanks
Ken
cpuken is offline   Reply With Quote
Old 04-06-2004, 06:29 PM   #2 (permalink)
I forgot about posting this question a while back...
I haven't resolved this issue so, hopefully someone will chime in with some ideas.
Ken
Old 04-06-2004, 07:13 PM   #3 (permalink)
Car: 2008 128i
Trunk?
2008 128i Jetblack
Old 04-06-2004, 11:04 PM   #4 (permalink)
Defector
El Presidente's Avatar
is it factory HU PNP or RF modulated?
If it's the factory one, the wire will only reach so far. What's wrong with the factory location anyway?
Old 04-11-2004, 09:32 PM   #5 (permalink)
No, it's not a factory head unit... it's a Kenwood unit.
On a 528i I see that there's a special hidden panel where the factory unit is mounted. This way it doesn't intrude into the normal trunk space.
On another BMW (don't recall what model) the disk changer is sort of hanging from a shelf in the truck... again, not blocking any of the available trunk floor space.
The 318ti has a small trunk to begin with so mounting it on the floor of the trunk will interfer with my ability to safely put my golf clubs in there.
I was just curious where a factory changer is mounted or if someone has come up with an even beter mounting location.
Ken
Old 04-11-2004, 10:24 PM   #6 (permalink)
Car: 2008 128i
was/is a factory changer even an option in the 318 TI's??
2008 128i Jetblack
Old 04-11-2004, 11:32 PM   #7 (permalink)
Defector
Oooooooo, I gotcha now.
Yes, all other BMWs I am aware of use some kind of mounting bracket that does not intrude into the cargo space. However, I have never seen a changer in a ti, and I don't know if there is a factory mounting point or not.
On any other hatchback I've seen, its always bolted to the floor. What I suggest you do is go to the good ole home depot, find some solid brakets and steel or aluminum (if you can cut it, if not, use wood) and fabricate a mounting bracket on the bottom of the rear shelf.
Old 04-20-2004, 11:12 AM   #8 (permalink)
Car: 2008 128i
You could also try a verticle mount on the side of the trunk or back of a seat to help save some cargo space.
2008 128i Jetblack
Bmw Disc Changer 318ti Dillema!!! tonymasone 3-Series (E36) 9 12-03-2004 08:40 AM
OEM changer and head unit mystery BobCT Audio and Electronics 4 08-04-2004 11:50 AM
alpine unit with Pioneer changer - not working BobCT Audio and Electronics 14 06-28-2004 10:48 AM
E36 CD Changer Mount bolt spacing question. thekid Audio and Electronics 6 05-07-2004 07:51 PM
