| What is this white stuff inside the amp? Hi
Been getrting a crackling amp, so decided to open it up to check for security of connections and spray with switch cleaner. found metal filings which might be the cause..
There is a white paste separating the casing from the circuit board. It resembes silicone but is wet. what is it? I would like to clean it all up and apply a little more again.
Thanks
Simon |
