Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-13-2007, 03:45 PM   #1 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
Photos: 0
MiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond repute
Send a message via AIM to MiguelACA
what size wire to run for multiple amps?
da_bull, ur expertise is needed yet again...
i pretty much sold the jetta already, but took out the amps and subs, and just left the headunit
ive learned alot about wiring amps and subs and stuff in my past cars, what im still not too sure on is the whole wire gauge size thing...
ill get right to the point now...
i have 2 amps...a 500 watt monoblock for the subs, and a 600 watt 4 channel for the speakers...how should i approach the power wiring? should i get a thick power wire from the battery into a distribution block? or 2 thinner wires and just stick each one into an amp? what gauge size? i wanna do my next install as clean and professionally looking as i can, without taking it to someone.
should i get a capacitor?
also, i will be installing an indash flip out dvd headunit thingy, but that i know how to install
EDIT: if i decide to not use my headunits amp remote turn on wire, and instead decide to put a switch to manually turn on and off the amps, as in getting the remote current from the battery, what fuse, if any, should i use?
<iframe src="http://gamercard.xbox.com/MiguelACA.card" scrolling="no" frameBorder="0" height="140" width="204">MiguelACA</iframe>
MiguelACA is offline   Reply With Quote
Old 08-13-2007, 07:35 PM   #2 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
4 strands of 00 gauge should be enough...
-There's no place like 127.0.0.1
-"Wheel Sucks"
Old 08-13-2007, 07:56 PM   #3 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
Photos: 0
ummm...so should i run all of them from the battery? or....sorry, i dont get ur post...
edit, actually...i picture that...the 4 00 strands...thats thicker than a garden hose...lol
Old 08-13-2007, 07:57 PM   #4 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
I usually like the one large wire to a distribution, but it depends on the car. One strand of 4 gauge should be enough. Fuse/breaker it at the battery, as close as you can to the battery.
The rule of thumb about capicitors is 1 farad for every 1000 watts. I would get one for your system, you're right there, and it'll help with the headlights dimming with the bass notes. Some capacitors have the distribution built in and are pretty clean that way. Something like this would also keep you from buying an additional distribution block after the cap in the back. Put the cap as close to the amps as you can cleanly.
I really dont like putting a switch in for the turn on. We used to install them for people at my old shop, but its cool for about a week, then you just end up leaving it on, and sure enough leave it on overnight (maybe not you, but your designated driver, sister, mom, someone) one time and wake up the next morning to a dead battery. You can do it easily enough and I can help you out doing it, but the switch will have to be on every time your want to listen to something, and I can't figure out any situation where someone would want the radio/dvd on but not the amps. Either way, I can help ya out...
Good luck...
Bill
-"Wheel Sucks"
Old 08-13-2007, 08:00 PM   #5 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
Photos: 0
cool, so 4 ga wire from battery to a distribution block, then what should i use for each amp? 8 ga enough? how about for ground? 8 ga ground on each amp enough? also, should i fuse each power wire that goes from thr distribution block to each amp?
Old 08-13-2007, 08:11 PM   #6 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
Photos: 0
im just full of questions, what amp fuse should i use on the 4 ga wire at the battery?
Old 08-13-2007, 09:06 PM   #7 (permalink)
drz
master of his domain
drz's Avatar
Car: e36 2.8i; e46 zhp
Photos: 0
What if he puts a relay inline with the switch? The relay coil can be energized from the battery ignition, or from the accesory position in the key, so that when teh car is off, the amps are off regardless of whether he forgot to turn off the switch
Turkey Fleet Bond Holder
Old 08-13-2007, 11:23 PM   #8 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
8ga should be fine for each amp as long as its relatively short. Its not a bad idea to fuse it in the back too. Yeah at least use an 8g ground for each amp. You always want to use the same size wire for your ground that you do for the power.
Also, take a look at your factory battery wiring. If you have a scrawny piece of 10-12 ga wire for an accessory ground (one 6ga. for the starter and usually a little bitty 10-12ga wire to the inner fender for all of your accessory grounds, i.e. brake lights, rewind lights, license plate lights, dome, etc.). Get rid of that wire and add at least a piece of 8ga from the battery to the fender. Your car uses the metal in the body as the return back to the battery and if its not very big, that can very easily be a bottleneck.
Check the owners manual on the amps and see what they recommend, add them together and fuse it at that.
Actually the easiest way is to put the switch on the remote wire so if you turn the radio off, or the key off, it'll keep the dead batteries at bay. But what you are talking about would work too. Theres about a half dozen ways we could wire it. Relays scare some people
-"Wheel Sucks"
Old 08-14-2007, 12:54 AM   #9 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
Photos: 0
cool, thanks alot!
i want to start buying the little things now, like the distributor block and fuses holders and stuff like that, dont want to buy a kit, cuz i may buy a bimmer, and all that extra power/ground wire will go to waste with the battery in the trunk
Old 08-14-2007, 06:32 AM   #10 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
Unless you buy a 5er, then they're under the hood...
-"Wheel Sucks"
Old 08-15-2007, 12:41 PM   #11 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
Photos: 0
learn something new, but yea, im trying hard to get an e46, how hard is it to run wires through those? i guess since the battery is in the trunk, i can run speaker wires down one side and rca's down the other no? it was such a pain in the ass to run 3 pairs of rca's and 4 pairs of speaker wire down ONE side of the jetta, i still have no idea how i managed to hide all that cable???
and because i was bored, a few pics of the audio stuff thats going into my future ride, may not be the best, but it gets the job done! and after i got my window broken and all my shit stolen....im not looking to spend too much anymore!
Old 08-15-2007, 07:45 PM   #12 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
All these cars are put together well, hence tearing into them and running wires are kind of a pain in any of them. Not REAL bad, just time consuming. I am guessing BMW didnt ever think anyone would want to upgrade anything. Molded carpets and form-fitting door sill plates, make it a little awkward to run wires. But at least you wont have to run power cable through there. As short of a run you have, you could just run 2 strands of 8 ga. straight to each amp (through fuses of course).
-"Wheel Sucks"
vB code is On
Remote Turn-on wire from aftermarket head unit to 2 amps? Iceman2k12 3-Series (E21, E30) 2 03-27-2007 05:33 PM
test one two... daki77 Test Forum 3 08-02-2006 06:55 PM
Standard Stereo Upgrade! onlinegamesnz 5-Series (E12,E28, E34, E39, E60) 6 07-29-2006 02:31 AM
DDE/City Light Switch 97alpineM3 3-Series (E36) 14 02-05-2006 12:07 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
