Upgrading Stock Alarm System - BMW Forum - BimmerWerkz.com
Old 10-02-2004, 11:27 AM   #1 (permalink)
Henri is an unknown quantity at this point
Thumbs down
Hi all B) I searched a while without any success for the information I need.
I have a 318i 1998 (e36) with what I suppose is the stock alarm system. I have a 3 buttons remote that locks the doors and enables the alarm. If I open a door without the remote... big panic :P
So... Is this system good enough... I heard of Stellar or ?? upgrade?? Is it that simple to install?? Why is this better? I will not put "jobber" alarm that will need a lot of wire cuts to make it work, that sure!
Thanks for your replies
Henri
Henri is offline   Reply With Quote
Old 10-02-2004, 12:25 PM   #2 (permalink)
Defector
El Presidente's Avatar
Both are fine. If you have one, there is no need to switch to the other.
Old 10-02-2004, 12:40 PM   #3 (permalink)
Car: 2008 128i
Steallar good if it works right... mine mostly works. my parking lights don't flash and windows don't go up but I have a few therorys to that one.
Stellar uses the code hoping stuff and is more expandable. Stellar uses a shock sensor vs a window break sensor so if someon hits, bumbs or cat jumps on your car it may set off the alarm depending on the sensitity level you set. Rhe sensor is 2 stage so i will warn then alarm. and you can add another sensor like a window break, ultrasonic sensor, or proximty.
2008 128i Jetblack
Old 10-02-2004, 05:55 PM   #4 (permalink)
Ok, thanks for the answers! Regarding my stock alarm... where are the sensors? Can I adjust the sensitivity??
Old 10-02-2004, 06:05 PM   #5 (permalink)
Car: 2008 128i
the stellar allows for that change on the shock and other sensors. the BMW has an adjustment that can bemade by opening the alarm and adjusting the 2 switches in there.
2008 128i Jetblack
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
Upgrading Stock System waleckaa Audio and Electronics 8 11-13-2004 03:37 AM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
