Subwoofer Problem - BMW Forum - BimmerWerkz.com
Old 06-20-2005, 10:43 PM   #1 (permalink)
aotiko is an unknown quantity at this point
I didn't know where else to post this so I hope someone can help me out. I was playing some music and suddently my bass just stopped working. I looked in my trunk and the bass was getting NO power, it didn't move one bit. The light is on to my amp but I don't know if it is broken or what. Has anyone else had this problem before?
aotiko is offline   Reply With Quote
Old 06-21-2005, 01:26 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Moving to the audio forum.. you might have more luck there...
Les
1997 E36 M3 1990 E30 325i
Old 06-21-2005, 05:28 AM   #3 (permalink)
da_administrator
da_bull's Avatar
first thing...unplug the subwoofer and use any other speaker (that you know that works) and hook it to your amp to see if the amp still works. If your amp works you have a bad sub, if it doesnt work, ask a buddy to borrow his amp to test your sub to make sure it still works (or take it inside and hook it to your home audio system).
Sometimes a sub lets go and it takes the amplifier out with it (I've seen it too many times).
good luck...
Old 06-21-2005, 07:02 AM   #4 (permalink)
napalm is an unknown quantity at this point
One you can do is remove the Sub from the speaker box. Attach speaker wire back to the sub. Take the positive side and hold it to a cordless drill battery (Preferably 12volt or 9.6, if neither is available, just use a 9volt battery people use in firealarms). Take the negative side and hold it to the negative side of the drill battery, for 2 seconds. If the sub 'pops' or moves outward, (if you have the polarity backwards it moves inward), then your speaker still has life in it.
This doesn't mean the sub is 'not' blown, but it is likely you are having problems outside the sub.
I'm late to work, so try this, if it doesn't work, post it back in reply. We'll figure out whats wrong with it.
napalm is offline   Reply With Quote
Old 06-24-2005, 12:04 PM   #5 (permalink)
thanks I'll try all of this when I get time
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
Alpine 9835 Fm Tuner Problem ultraviolet353 Audio and Electronics 7 09-22-2004 11:09 PM
