Originally posted by matt323is@Oct 6 2004, 05:38 PM I have a JL 12w3v2 subwoofer and an XTANT amp from my last car and am interested putting it in my 1998 323is. The car has the stock stereo which I dont think sounds that bad. I am on a limited budget because I am paying for the car. Are there inputs on the stock headunit? Has anyone here done this? The only other option ill consider is one of the new alpines that has the 512 color selection....wouldnt want to ruin the wonderful color scheme.... and help is appreciated. [snapback]206352[/snapback] |
Yeah.... even though this may sound pretty lame... i did exactly what matt 323is is thinking of doing.... I ran a subwoofer from my stock system using a Sony Xplod amp...
I did not change any of the speakers in the car... or anything of the like... The sony xplod amp that i got had a high level input to it..... this allowed you to take a signal from a Left & Right speaker (both +ve and -ve).. and feed it into the amp as the main input...
I searched this site and came up with the amp wiring diagram (will try and post link later... in the mean while do a search for amp wiring diagram).... and found the different connections coming from the amp going to the speakers...
Using a wire cutter (careful now... dont want to cut throgh the wire, only remove the insulation) i took a signal (+ve and -ve) from the R & L speaker output... I also took a signal from the "remote".... which turns on and off ur amp.... For the power and GND i used the battery (gotta love the battery in the trunk) I could've used a body GND pt too...
After hoooking the amp up it was only a matter of connecting it to my woofer box... and then finding a place to mount the amp.... I decided to mount the amp on the woofer box (for simplicity)... The entire operation took abt 2hrs (first time) would prob take abt 45 mins now...
Ensure that you have electrical tape... Screwdrivers, wire cutters, knife... and of course your ground and power amp wires.
I must say the SYSTEM sound GOOOD.... maybe not as great as $400+ systems but for the simplicity and ease of installation the bass adds character to the system set up :-D....
Hope this was useful... if i think of anything else i'll post it....
ENJOY!
