Subs cause brake lights to go out - BMW Forum - BimmerWerkz.com
Old 04-04-2007, 10:40 AM   #1 (permalink)
RichM is an unknown quantity at this point
Hi there,
Since I got a sub (only 300w) I've been having trouble with my brake lights. The bulbs are fine, but the lights seem to have a dodgy connection. I am not sure what I can do to resolve this issue. Obviously I stopped using the sub, but the damage seems to have been done. (If you call it that)
Any suggestions? I assume it must be a fairly common issue?
Any help would be much appreciated. Need to get this sorted before I get bummed or pulled!
RichM is offline   Reply With Quote
Old 04-04-2007, 12:58 PM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
I'm going to transfer this to the audio section where I believe you will have better luck.
Old 04-04-2007, 08:08 PM   #3 (permalink)
da_administrator
da_bull's Avatar
I would start with checking the sockets for the bulbs first. Make sure the bulbs are in there tight. If your amp would draw a bucketload of power it might make them flicker a little, but not make them go out. Also check all your amps connections, making sure you have a good ground and large enough wires to handle what the amp requires. A 300 watt amp takes about a 10 or 8ga. wire.
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
Left Rear Brake Lights Out? mondo336 3-Series (E46, E90) 3 10-15-2006 08:54 AM
Brake Lights Stay On Nealdavis4 3-Series (E21, E30) 0 12-17-2004 01:21 AM
Brake Lights Failure, Now. bkstaylor 3-Series (E36) 1 11-24-2004 09:45 AM
