Stock HU w/ AMP + SUB - BMW Forum - BimmerWerkz.com
Old 06-17-2004, 11:37 AM   #1 (permalink)
epistemology is an unknown quantity at this point
Ok, did some searching and i found a post but it turned into a flaming post.
anyways, my question is, i have a 1992 325i (E36). I dont want to remove the stock HU but i am concerned with the high level inputs going into the amplifier. I am having a professional do this install. Will they use a converter or will they use the high level inputs?
If so, how bad is it to use the high level inputs? Is there a noticable difference between them and the RCA's????
Thanks
Dave
epistemology is offline   Reply With Quote
Old 06-17-2004, 01:02 PM   #2 (permalink)
Defector
El Presidente's Avatar
Converters are dirt cheap, why not DIY? Hell, I've amassed a small collection. I'll send you one for the cost of shipping. If you insist on having it done at a shop, don't risk it and tell them you want a converter put in.
Old 06-17-2004, 01:33 PM   #3 (permalink)
Car: 2008 128i
new hu should work fine with the factory amp. many still have it installed and working with after market HUs...
people run into more difficulty when just tring to put an aftermarket amp while maintaing stock speakers and HU
2008 128i Jetblack
Old 06-17-2004, 01:54 PM   #4 (permalink)
how much do the converters cost? The only reason im having a shop do it is because i dont feel like touching this car. I have a 95 Probe GT that i have done everything to, kinda want that "if they fugg it up" "they pay for it" feeling.
Thanks El Presidente
Oh, 007ben i treid to say i wanted to KEEP the STOCK UNIT and use an aftermarket sub and amp.
Old 06-17-2004, 02:21 PM   #5 (permalink)
Car: 2008 128i
one of those days.
2008 128i Jetblack
Old 06-17-2004, 05:17 PM   #6 (permalink)
Defector
I think i have a blaupunkt converter and a jenson converter. Take your pick.
I know have the J one. If I have the B one, it is new and never used. Came with my current amp. In a store, converters run anwhere from 10-30, depending on brand and markup. It'd be about $4 USPS.
As for working on this car, it is probably be easier than the probe.
Old 06-18-2004, 07:57 AM   #7 (permalink)
do you think they will use a converter in the install?
Old 06-18-2004, 10:14 AM   #8 (permalink)
CiscoKid's Avatar
dont use a converter
i had one.. it sounded like shit... just plug the H/u straight into the wireharness
Old 06-18-2004, 02:15 PM   #9 (permalink)
Defector
umm.
I don't think you are clear on what he is doing. There is no HU to plug into a harness.
RCA converters use splices on individual wires (rear pos and neg for each side, respectively).
Old 06-18-2004, 08:20 PM   #10 (permalink)
WOT in Reverse
jllphan's Avatar
Yes, a line level converter is better than hi-level inputs on the amp.
It is still a very dirty signal, and as 007stated earlier, it is easier and a much better idea to add an aftermarket head unit and then add speakers and a sub than leaving the stock rocker in an replace the other speakers...
Old 06-19-2004, 12:36 AM   #11 (permalink)
Hey fellas,
thanks for all the input.
Well, i was just looking at my dad's setup
3 JL w0 10's against a 400w coustic amp running off the high level inputs and damn, it sounds crazy with the gains turned down.
I dont think it will be that bad, we will just have to see monday.
Thanks again for all your post......HAVE FUN AND UP!!!!!!!!
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
How do you install amp and subs to a stock headunit? t5sesco Audio and Electronics 2 09-16-2005 01:26 AM
Back To Stock Sale Look!! M3 Parts bigbris1 OEM Parts 29 07-14-2005 12:59 PM
How To Access Stock Amp lttlwd04 Audio and Electronics 5 04-24-2005 02:21 PM
Stock CD changer Shudogg 3-Series (E36) 5 05-08-2004 06:20 PM
