Stock Head Unit Removal - BMW Forum - BimmerWerkz.com
Old 06-27-2004, 10:29 PM   #1 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Kissner is on a distinguished road
Send a message via Yahoo to Kissner
Can anyone give me directions on how to remove the stock head unit from my M3? I wanna know what i'm doing before i start rippin apart the dash. Thanks
Kissner is offline   Reply With Quote
Old 06-27-2004, 10:32 PM   #2 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Ignore the steering wheel on the right side, i flipped the pic on photoworks and saved it before i realized it was backwards
Old 06-27-2004, 10:39 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
Simple.
Locate the two small flaps on either side of the oem deck.
Flip them open.
Insert an 8mm hex wrench(allen wrench works as well)
Twist counter clockwise.
Pull.
That's it. Pretty straight forward as is the wiring
Old 06-30-2004, 01:51 PM   #4 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
That's what i tried doin. I thought i had the wrong size wrech but the screw just won't fit out the holes. Should i just make the hole bigger so the screw fits or what?
Old 06-30-2004, 09:56 PM   #5 (permalink)
WOT in Reverse
jllphan's Avatar
I dunno. It worked for me as well as others on this thread. Did you try the hex nut or an allen wrench. The hex should deffintately work. If all else fails, try a torx bit of the same size. It really shouldn't be that hard....
93 325 Rims With Stock Head Unit newuser Wheels and Tires 1 08-12-2005 02:43 AM
Stock Mp3 Head Unit For E46? Kionon Audio and Electronics 0 04-06-2005 08:16 PM
Cd Changer Adapability nookatee Audio and Electronics 5 02-05-2005 11:36 PM
Removing Stock Head Unit 412underground Audio and Electronics 1 01-05-2005 09:11 PM
How to add an amp to stock dsp head unit? 528Coug Audio and Electronics 1 09-03-2004 05:12 PM
