Standard Alarm Problem - BMW Forum - BimmerWerkz.com
Old 06-12-2005, 11:48 AM   #1 (permalink)
exxy is an unknown quantity at this point
i recently charged the battery on my 318i but on connecting the terminals the alarm sounds - i dont have the remote or the key to turn it off. the car was running fine before this without any alarm probs, can i shut it down by any other way ?
many thanks
exxy is offline   Reply With Quote
Old 06-12-2005, 02:58 PM   #2 (permalink)
Super Moderator
dutchbmw's Avatar
Moved to Audio & Electronics forum.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 06-12-2005, 09:44 PM   #3 (permalink)
da_administrator
da_bull's Avatar
If its a factory alarm, you can lock/unlock the door manually with the key, if its aftermarket, your stuck, you will have to get the remote for whatever you have or unhook it completely.
Old 06-16-2005, 02:27 AM   #4 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
[snapback]353035[/snapback]
Did you put that alarm in yourself? There should be a button or switch to turn the thing off. I wouldn't recommend taking the whole thing out if you can avoid it. Have it towed to a car audio place. They probably need to get in your car, but they can reprogram a new key fob for ya. I think it takes a few days though. Would cost maybe sixty bucks
BeachBunny is offline   Reply With Quote
Old 06-16-2005, 10:55 PM   #5 (permalink)
napalm is an unknown quantity at this point
many thanks
[snapback]352887[/snapback]
I'm a 12volt tech at a 'car stereo' shop.
If its factory its typically lock unlock in the lock cylinder of the door.
'Valet mode' If its aftermarket it can be done several different ways depending on the brand.
My experience shows about 80% of the aftermarket alarms are disabled w/o the keypad using the ignition key and the 'valet' button. Most of the sequences go as follows:
1. Enter vehicle
2. Insert ignition key and turn the key to the 'on' position (Just before the 'start' position)
3. Press and hold down valet button until red light stays 'on' (LED alarm indicator)
In some cases its a toggle switch which will require you to 'flip' the switch ONE time.
Viper and most DEI products require the use of the keypad to enter the vehicle in valet mode.
Hope this helps, any other questions I can help with PM me, as I don't normally watch this forum thread.
napalm is offline   Reply With Quote
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
'96 318i Alarm Problem - bit missing? rp51 3-Series (E36) 1 09-16-2005 03:52 PM
Car Central Locking Alarm Problem... dbrook007 3-Series (E36) 0 06-29-2005 08:24 AM
