| sounds like the left speaker is aftermarket. i don't know the specifics of the stock e34 amp, but if it's like the e36, the crossover is built into the amp, so it will have separate outputs for high, mid, woofer. so for the front it can have up to 6 wires per side. if you found only 2, that sounds fishy.
__________________ |
