SOUND SYSTEM - BMW Forum - BimmerWerkz.com
Old 12-02-2003, 09:43 AM   #1 (permalink)
///STEALTH///'s Avatar
///STEALTH/// is an unknown quantity at this point
HI guys just wondering who here has wired their own car and where did ye run the wires from the amp + how do you take the back seat out in a 318i saloon .
thanks , all answers much appreciated
LIVE NOW PAY LATER
///STEALTH/// is offline   Reply With Quote
Old 12-02-2003, 02:36 PM   #2 (permalink)
Defector
El Presidente's Avatar
should go in the sound forum...
but, to answer your question:
the rear seat bottom unclips when you pull up on it, giving you access to areas you can drill through to run wires to the trunk if you can't find a factory hole. My amp is wired with 10 guage wire from the battery on the right, and runs to a ground screw I drilled over on the left. I ran the RCAs from the HU to amp under interior door sills, then under the carpet to the hole from the backseat and into the trunk.
Old 12-02-2003, 02:43 PM   #3 (permalink)
Defector
my wires
Old 12-02-2003, 04:17 PM   #4 (permalink)
BlackTape's Avatar
BlackTape is an unknown quantity at this point
Send a message via ICQ to BlackTape Send a message via AIM to BlackTape Send a message via MSN to BlackTape Send a message via Yahoo to BlackTape
nice use of PAINT.....
and the ground wire gose where?
<img src='http://www.satchmo.com/cashmoney/btymers.jpg' border='0' alt='user posted image' />
<span style='font-family:Impact'><span style='font-size:21pt;line-height:100%'><span style='color:red'> GANGSTA Tape</span></span></span>
BlackTape is offline   Reply With Quote
Old 12-02-2003, 04:30 PM   #5 (permalink)
Defector
the ground wire goes over by the spare tire almost by the tail light. My original system had 2 10s and the amp was mounted off to the side by the ground wire. Ill see if I can dig up an old pic.
Old 12-02-2003, 04:37 PM   #6 (permalink)
Defector
Im getting ready to install a cap on the the other wing of the box. yet more wires to run. o boy.
As you can see, with my old amps location, the ground is slightly to its right.
Old 12-02-2003, 10:19 PM   #7 (permalink)
PhiLLaY is an unknown quantity at this point
hi just notice your sub box, does that work good? its got a unique shape
PhiLLaY is offline   Reply With Quote
Old 12-03-2003, 11:47 AM   #8 (permalink)
Defector
I built it myself to fit the shape and house the amp. I was a little concerned it would sound bad , but its filled with 20oz of polyfill to help add volume, and it sounds great.
E39 2000 Sound System Upgrade Golden Boy Audio and Electronics 5 02-01-2007 09:34 PM
Sound System Upgrade Scotty Dangles 5-Series (E12,E28, E34, E39, E60) 5 12-22-2004 03:56 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
Upgrading E30 sound system... SeanH Audio and Electronics 0 08-13-2003 08:26 PM
