some more base in my e30 convertible? :) - BMW Forum - BimmerWerkz.com
Old 09-02-2004, 04:47 PM   #1 (permalink)
javieruz's Avatar
javieruz is an unknown quantity at this point
Send a message via ICQ to javieruz Send a message via MSN to javieruz
hey guys, i was wondering what would be the best solution to "base-up" my e30 convertible... (i dont need any super-extra-shaking woofer but just something decent and pleasant) i think a tube subwoofer is what people recommend for convertibles, or at least this one since woofer in trunk does no good (my friends tried to put a sub into the trunk on his e30 convt. but did not realize that the there is the sheet-metal divider between the trunk and the rear seats so it just sounded really horrible).
So, what is the best place to put any sub (behind the driver seat or maybe fit it under the glove box?), i have MTX AMP i would also like to use, should i install it under the driver seat?
i did not find any other topic dealing with this convertible...
what do you think?
thanks!
<span style='font-size:13pt;line-height:100%'><span style='font-family:Arial'>'87 325i Convertible</span></span>
javieruz is offline   Reply With Quote
Old 09-02-2004, 06:13 PM   #2 (permalink)
Defector
El Presidente's Avatar
with a vert, your best option is generally to go with a bass tube or an Infinity Basslink.
Old 09-22-2004, 09:16 PM   #3 (permalink)
RJHD3 is an unknown quantity at this point
I receive my 1994 325ic on Friday. One of the stops over the weekend will be to replace the stock speakers with Infinity Reference speakers, and to have a sub installed.
So far the two recommendations are clearly the BassLink and the Bazooka 10 inch.
My ideal is for a system that sounds loud and clean with the top down as well as up. Hitting hard is a perk, but Sound Quality is my preference.
Any words of recommendation between them? General preferences for convertible owners?
And what about ideal mounting placement?
Thanks in advance. I've spent the last two days reading in anticipation, and there are some awesome contributors here.
-RJ
RJHD3 is offline   Reply With Quote
Old 09-23-2004, 10:35 AM   #4 (permalink)
mlomker is an unknown quantity at this point
Send a message via Yahoo to mlomker
I'm very happy with the Basslink in my sedan, now that I have the gains properly adjusted. EP is an installer, but I doubt that many other people have tried both solutions in the same car to give you a perspective.
mlomker is offline   Reply With Quote
Old 09-23-2004, 11:03 AM   #5 (permalink)
Thanks mlomker.
Based on the reviews I've read it seams to be quite adequate for a sedan or coupe, but there are a lot of comments on review sites that make me doubt how it will do with the wind noise of a convertible top being down.
That's my concern....loud enough to still sound good at 60 with the top down.
Old 09-23-2004, 11:27 AM   #6 (permalink)
Defector
bass links hit far harder, louder, and clearer than bass tubes. As for moutning options, inside the car would be ideal. Unfortunately, there's not really room. The best thing to do is play around with where it is and which direction it faces until you get the desired effect. Infinity also makes another variant of the basslink for trucks and hatchbacks. Retail is around $500, but my discount w/ them cuts that more than in half. I haven't read the specs much on them , but I think that if they are thin enough and enough foam could be cut away but still provide support for passengers, it could fit under the rear seats.
Old 09-23-2004, 11:29 AM   #7 (permalink)
Defector
nevermind. Just looked at the dimensions. Its 3.75 on end, but over 6 on the other.
http://www.crutchfield.com/S-5EZZk9sxXER/c...&display=XL#Tab
Old 09-23-2004, 11:39 AM   #8 (permalink)
Thanks for the suggestion El Presidente.
I'll also check out custom box construction ideas this weekend, and see if there's a way to port it through the back seat or some such.
Will know more after I spend time with the car. It arrives at 2:30 tomorrow. *growing impatient*
-RJ
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 04:27 PM
M3 Convertible, Lip Spoiler BevHillsE46 M-Series (M1, M3, M5, M6) 3 08-01-2005 05:20 PM
M3 Convertible, Lip Spoiler BevHillsE46 3-Series (E46, E90) 0 07-31-2005 08:21 PM
Bluetooth on E46 Convertible DoubleJava Audio and Electronics 1 07-05-2004 11:31 PM
Coupe or Convertible? consultant 3-Series (E46, E90) 6 04-23-2004 04:17 PM
